What things should be routine maintenance that most will not think about?
Old Sep 24, 2013 | 12:30 PM
ben774's Avatar
Default What things should be routine maintenance that most will not think about?
I know you could change your oil, and filters, check for leaks, do injectors and change the pump and lines and everything like that. But these trucks are 20+ years old, what things should be checked or done to "freshen" them up or make them run just that little bit better? And what are some little cheap parts that should be replaced at a regular interval?
Old Sep 24, 2013 | 02:57 PM
4x4manonbroke's Avatar
Make sure u have clean fuel, and SCA Precharged coolant .... cavitation will kill it quick , I'm currently doing Head gasket on mine ... port matched everything ..... also they really like synthetic oil .... I have been running RoyalPurple 15/40 for about 3 yrs. In my 7.3idi .... averaging 19.7 mpg on freeway and 16.8 city ...... hopefully the port matched everything will get me over the 20 hump
Old Sep 25, 2013 | 10:54 PM
haiden66's Avatar
Not routine really, but check grease fittings where ever you find one on the truck...
Old Sep 25, 2013 | 10:56 PM
ben774's Avatar
I've heard of doing your timing.. How would someone go about making sure it's in tune
Old Sep 26, 2013 | 08:10 PM
Specifically you need a pulce timing devise ... most of us know how to do it ... some the hard way and some the right way .... its a bit leingthly and difficult to explain in a non tech way if you know what i mean....... easier said then done kinda thing
nomoney
Aug 5, 2015 09:16 AM
petew
Jul 2, 2015 05:40 PM
Jesse92cummins
Jun 10, 2015 04:48 AM
hot48chev
Jun 7, 2015 06:04 PM
cooler364
Mar 15, 2015 04:13 PM
