88 350 brake lights
Old Sep 18, 2013 | 07:16 PM
POWERSTROKEMANIAC's Avatar
Default 88 350 brake lights
So the genius before me decided to rewire the brake light trigger for a trailer brake controller and almost set it on fire. I bought a new trigger and rewired it but when I put the fuse in the panel that is supposed to be factory wired it still doesn't work! Any ideas?
Old Sep 18, 2013 | 07:59 PM
4x4manonbroke's Avatar
bad brake switch .... bad bulbs, ummm ... relay possibly
Old Sep 18, 2013 | 08:02 PM
Bulbs are fine and got the new trigger on it.
Old Sep 18, 2013 | 08:12 PM
bad relay ... or loss of ground @ rear of truck to ground the lights
Old Sep 18, 2013 | 09:44 PM
Nah see they still come on with the lights just not with brakes. They run off the same fuse as the cruise control and hazardd and they dont work either.
Old Sep 18, 2013 | 11:07 PM
Irish_Alley's Avatar
are you getting 12volts at the fuse?
Old Sep 19, 2013 | 10:03 PM
something is majorly screwie here .... its a real simple system .... somewhere along the line you loosing your break signal to thee rear .... gonna have to trace the wires, wire by wire ... i had to do the same because of a 7 way theat some idiot hacked in w/scotch locks ...
I FKing hate those damn things..... why not just short out the wiring and try again .... not even in an emergency would i use those damn things ..... argggggg ......
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Apr 15, 2015 07:29 AM
bypass-21
Jan 3, 2015 04:47 PM
yams
Nov 29, 2014 09:25 PM
