Cheapest 120HP add on?
Old Aug 10, 2013 | 05:18 PM
derherr65's Avatar
cool Cheapest 120HP add on?
What is the cheapest way to add 120HP to a daily driver. Daily driver reliability and durability required.
Old Aug 10, 2013 | 05:27 PM
TheyCallMeCountry's Avatar
Edge Juiced with Attitudes cts programmer, bigger injectors and a 150gph lift pump.
Old Aug 10, 2013 | 07:37 PM
derherr65's Avatar
$830 + $400 + $400 = $1630 plus shipping. Has to be a cheaper way.
I also have a FASS DRP, not high performance, but better than stock.
What about 125HP injectors and a boost fooler? How would it run and drive, and any durability issues?
Old Aug 10, 2013 | 09:23 PM
Hey you wanna spend 5k for a twin turbo set up like i did. Be my guest. Bring it to my shop, and I will build it up. Got a budget your trying to stay with in?
I didn't see your split post my bad. Whats your GPH rating on the FASS?
Last edited by TheyCallMeCountry; Aug 10, 2013 at 09:23 PM. Reason: Automerged Doublepost
Old Aug 11, 2013 | 05:51 PM
jigabop's Avatar
FASS DDRP can NOT keep up with performance mods..even FASS reps will tell you this...it is meant for a STOCK engine only.
any power adders will require an upgraded lift pump...95GPH+ minimum.
Old Aug 12, 2013 | 06:07 PM
jigabop's Avatar
You spent too much...
you can get a complete set of S300/S400 twins brand new for $3000
that's both turbos, plumbing, oil lines, support brackets, aux oil drain, and hardware.
only thing you gotta do yourself is paint it and assemble it on the truck.
Old Aug 13, 2013 | 01:00 PM
turbostang7's Avatar
Find used go fast goodies, 150hp injectors, edge or quad, possibly smarty, and lift pump and your good to go, until your trans goes
Old Aug 13, 2013 | 01:30 PM
jigabop's Avatar
I agree.. Used can be a good way to go...I just sold my old DDP 150hp injectors a few weeks ago for $400. they made me 538hp 1078tq when I dyno'ed with them and most of my current setup (there have been supporting mod additions since then, but they were not power adders...just the new injectors were)
I'm just pretty much at the point now where my tired old SOVP44 is just running out of fuel and can't keep up with the heavy fueling or timing anymore. If I had a fresh SOVP I could probably easily break 600hp with my mods, but my tired old vp just can't pull it off...at least not on a mustang dyno ...could probably pull it off on a dynojet.
BGbowhunter
Jun 20, 2015 10:17 PM
EasTxOilfields
Apr 23, 2015 09:30 AM
Jojorusso111
Nov 2, 2014 09:33 PM
