S&B install question?
Old Jun 13, 2013 | 09:11 PM
mark04's Avatar
Default S&B install question?
Just received my S&B dry intake kit today in mail on my birthday!!
1 question I have about the install tomorrow morning. It says in instuction that the bottom box cover is optional. Has everyone installed the bottom piece or have you left it out? In the instructions it says that there is minimal heat worries from it. I guess I'm also going to remove the silencer ring while I'm there. Is there any tricks to getting it out?
Thanks
Old Jun 13, 2013 | 10:19 PM
01trailerpuller's Avatar
Don't know about the intake but to get the ring out, a flat head and a pair of needle nose pliers is all I used. There is a edge of the ring that is pointed pry that till you can get the pliers under it then twist in and pull it out is how I did mine.
Older Cummins but same idea
It is on a 6.7 but it is the same process.
Last edited by 01trailerpuller; Jun 13, 2013 at 10:19 PM. Reason: Automerged Doublepost
Old Jun 14, 2013 | 01:41 PM
mark04's Avatar
Thanks for the reply. I'll see how it goes in the morning.
Well the install went great. Took 45 minutes. I did not have a small enough flat blade screwdriver for the silencer ring so i left it in there. The intake is not as loud as i thought it would be. I was hoping for mre. The quality of the kit is great though. Everything fit up just right with no problems. I also straightpiped it today too. Now it's sounds awesome. Next up some gauges.
Old Jun 14, 2013 | 04:59 PM
Your trubo whistle will go up ten fold when you remove the silencer ring.
Old Jun 16, 2013 | 02:07 PM
mark04's Avatar
Round 2: It took me all of 3 minutes to get the ring out this time. I guess I was just to hot last time and frustrated . Man it sounds really good now. The turbo screams!
450r racer
8
Dec 21, 2015 06:42 PM
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
scottxmorris
Oct 8, 2014 02:14 PM
