hard start
Old May 31, 2013 | 10:24 PM
stallings towing's Avatar
Default hard start
hello i have a2000 cummins 24 v rollback just purchased recently. Sense buying the truck it is hard to start when first cranking of the morning or after it has been shut off for a hour or two during the work day. I am not very knowledgable on diesel's but seems like it loosing it fuel prime because if you spend the engine over a few cycles (3 to 4 times) it fires right up. It also seems to have a very small fuel leak on drivers side of engine compartment and i can't seem to pin point that leak and I thought that may be my whole problem any ideas would bo greatly appreciated. Also truck has about 119000 miles on it if that makes a diffrence thanks
Old May 31, 2013 | 10:53 PM
1999stroker's Avatar
Check the fuel lines and make sure tightened correctly along with the lines going to the injection pump and coming from the tank.
Sent from my DROID RAZR
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
