Cruise control problem
Old May 16, 2013 | 11:24 AM
RivervalleyJohn's Avatar
Default Cruise control problem
Hello all.I got a GMC Sierra 6,5 td -95 and the cruise works fine just after start and works sometimes for hours,then when i turn it of it wont work until i stopped the engine for a few minutes,then it works again.I checked the brake switch and it´s ok. Anyone got an idea?
Old May 16, 2013 | 01:58 PM
racer55's Avatar
Multi function/turn signal switch?
PMD that is failing can affect cruise as well.
Old May 17, 2013 | 03:40 AM
Okay, i have tried three different pmd's and still the same. I don't even have to touch the signal switch,just the brake and then trying to resume very gentle and it's dead,sometimes it works if i go to neutral and turn the key of and starts again,still on the roll. Do you know where the cruise module is located?
Old May 17, 2013 | 07:19 AM
racer55's Avatar
It's the ECM.
Do you have any trouble codes?
They can interfere with cruise?
Still sounds like a bad signal/multifunction switch though?
Old May 17, 2013 | 08:05 AM
No trouble codes and runs like a charm.Mounted a chip from Engs motor and it works better then expected,less fuel consumption and more power. Can recommend that.
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
gregbushman
Ford Powerstroke 08-10 6.4L
Jan 9, 2015 11:59 PM
kryz9903
Jan 3, 2015 07:00 AM
