gutted afc not much smoke
Old May 8, 2013 | 10:41 PM
jonesy9310's Avatar
Default gutted afc not much smoke
Well i bought the truck with a gutted afc and i thought with it gutted smoke is supposed to be almost uncontrollable but if i hit it when i get goin it blows none i noticed the line from the wastegate to the afc was broke i was wondering if that would have anything to do with it. Not trying to blow more smoke but i thought it would im just making sure jothings wrong
Old May 9, 2013 | 10:05 AM
olsmokey's Avatar
i would go find the the parts at a junkyard and put the afc back together then tune the truck right
Old May 9, 2013 | 10:44 AM
Al31031's Avatar
if the afc is gutted and the pump isnt cranked up and the star wheel isnt cranked its probably not gonna smoke that much
Old May 9, 2013 | 11:38 PM
senotext's Avatar
if the line from the wastegate to the afc is broke, it would only matter if the afc was not gutted, a gutted afc uses no boost signal , sounds like everything else is stock or you have a fuel supply issue
Old May 10, 2013 | 01:12 PM
94 12valve's Avatar
if your running a stock plate that is why you have a "smoke" issue, as for the wastegate line that has no effect on your fueling if the afc is truely gutted. it will however play a factor in how long your turbo lives after you get the fueling right.
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sandlappa
Aug 23, 2015 09:20 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
