Putting a 6.2 into a 1962 c10
Old Apr 17, 2013 | 04:48 AM
OldDieselDave's Avatar
Default Putting a 6.2 into a 1962 c10
Hello all, I have searched and read some, but I have a question about 6.2s and manual transmissions. I am putting a 6.2 in a 62 Chevy short / narrow bed. It currently has a 230 L6 in it with the stock trans ( I think SM420 ) granny gear 4 speed. How ugly is the conversion of 6.2 auto in the truck to 6.2 with SM420 ? I have a th400 that is currently on the 6.2 and a700r4 variant from an 88 suburban R10 gas engine. But you know, I think I'd prefer the 4 spd with a Gear Vender's behind it. Thoughts? Recommendations?
I have decided the 62 must become diesel. BTW , I saw a thread about truck names.... truck's name is Heavy Metal. We pull stuff.
Thanks for the advice and comments
Dave
Old Apr 25, 2013 | 06:00 PM
u2slow's Avatar
I converted an '84 C20 Suburban from TH400 to SM465. I swapped to a 3.21 axle and 33" tires. Didn't really need overdrive this way.
You need a diesel flywheel. Gas clutch works. Driveshaft needed lengthening as I recall. Bellhousing and hydraulic clutch came from a '83-'87 truck. The '73-'82 version uses mechanical linkage.
SM420 might be a bit weak for diesel abuse. The iron bellhousing probably won't accept the diesel starter.
my 2 cents.
Old Apr 27, 2013 | 11:57 AM
Thanks for the info, I hadn't thought of the bellhousing (yet), I might have the 465 also as I never throw out anything.
Thanks again
Old Apr 27, 2013 | 07:14 PM
BarryB's Avatar
If it were me, I would try and find a newer 5spd set up from a truck with a blown motor. or wrecked. This way you would everything you'll need. converting your 62 to a hydro clutch wouldn't be that hard to either. my .02.
Old May 2, 2013 | 03:54 AM
I think I might have welded up the original hydro clutch hole oh well. I like the 5 speed Idea. heavy gas or diesel? or diesel apps only. don't see many Diesels in the bone yards here ( i think they are still earning a living some place)
Thanks again
Jackthesmallengineguy
Nov 12, 2017 01:25 PM
NSmachine44
Aug 16, 2015 09:25 PM
Aug 5, 2015 03:40 PM
jedder21
Mar 7, 2015 09:47 PM
84c10
Oct 13, 2014 09:10 PM
