Debadging problem, could use some help!
Old Feb 18, 2013 | 03:38 PM
PowerStrokin94's Avatar
ATTN Debadging problem, could use some help!
I have a 2000 cummins and I want to debadge it, im talking side moldings, door badges, tailgate cover. I inspected the side molding today and noticed my glue is already coming apart on the ends and there is a brown ring just under the edge of the molding(where car washes couldnt clean for 13 years) I tried using a little water on my finger and rubbing it off but it did nothing to it I would hate to get the molding and badges off just to have brown lines where it use to be. I know how to get the adhesive and stuff off just not sure about this brown dirt ring. I also noticed the paint under it seems to look pitted, would wet sanding it take that away? Ive included pics to help.
Old Feb 18, 2013 | 04:30 PM
Red_Rattler's Avatar
High Tech Redneck
Simple buff with a wool pad and some cutting compound and finished up with a super fine grit polishing compound with a foam pad should take cafe of that easily
Old Feb 18, 2013 | 05:01 PM
H.R.D's Avatar
Try gasoline on a rag for the dirt ring or rubbing alcohol....
Old Feb 20, 2013 | 01:48 AM
Thanks for the help guys! I did what Red_Rattler suggested and it came out great! I'm glad I stuck with it and did it cause the truck looks 110% better! I'm amazed how great it turned out, I was worried because its 13 years later and I'm pulling this stuff off but it looks like it came from factory without badges and moldings. I used a 3M "pinstripe remover wheel" from O'riellys ($48 bucks... Esh) to remove glue left on the paint followed by Red_Rattlers directions. Thanks again for the help you guys
Before...
Size:  80.7 KBAfter...
After...
Last edited by PowerStrokin94; Feb 20, 2013 at 01:49 AM. Reason: Automerged Doublepost
Old Feb 20, 2013 | 08:40 AM
daveO's Avatar
Looks good! I think I may have found my next project....
Old Feb 20, 2013 | 10:33 AM
DaveO go for it man, it's well worth it. I spent about 2hours working on it with my buddy and I believe an hour and a half was spent on drinking beer
I also used fishing line to cut the badges and moldings off. It helps to heat the badges with a hair dryer but side moldings just cut a bit of it and pulled it off by hand.
Last edited by PowerStrokin94; Feb 20, 2013 at 10:33 AM. Reason: Automerged Doublepost
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
