5.9 transmission issue?
Old Feb 3, 2013 | 05:35 PM
6.0 Warrior's Avatar
Default 5.9 transmission issue?
I recently bought a 2003 Dodge ram 2500 5.9 it has 120,000 miles on it and it's In great shape. It ran smooth until yesterday when I put a bulldog ppe on it. For some reason it only feels like a minor boost in power and if I take off from a slow roll or a dead stop it almost feels like the transmission has a hard time keeping up. It will bump a few times as it shifts and the exhaust will virtually make no noise. Also i get only a tiny barely noticable puff of smoke. Sorry I know that's a vague description but I can't think of any other way to describe it. Anyone know what this could be please help. This same tune was on my 6.0 and it made a world of difference. Could this be a transmission problem? I really don't know what it could be the tune is on performance and is supposed to add 120 horses.
Old Feb 3, 2013 | 05:39 PM
Red_Rattler's Avatar
High Tech Redneck
Bull dog ppe? Those are two separate companies but if you have a stock grabs with that much mileage on it your probably slipping the crap out of it. How does it drive with the truck put back to stock?
Old Feb 3, 2013 | 06:05 PM
When it was stock it shifted fine. Its a bullydog tune. When I put the tuneon my 6.0 it had 190,000 miles on it and it ran fine.
Old Feb 3, 2013 | 06:08 PM
High Tech Redneck
Two totally different trucks and transmissions, can't compare it that way saying it will be safe and handle it.
Old Feb 3, 2013 | 06:13 PM
So what should I do to fix it?
Old Feb 3, 2013 | 06:30 PM
GuyWithA24Valve's Avatar
Better build a new transmission.
Sent from my iPhone in the cab of a Caterpillar
Old Feb 3, 2013 | 08:02 PM
High Tech Redneck
Def start looking into rebuilding the trans for what you plan to be using the truck for and what HP levels you intend to be at. But until then I would def turn the tuner down to and economy or tow tune and see if it likes that
also pull the trans dip stick with the truck running and trans in neutral to see if its at the proper lever and see if its burnt color or smelling
Max713
Apr 17, 2015 01:18 AM
pcredneck03
Mar 22, 2015 05:51 PM
02Stain
Feb 17, 2015 10:21 PM
POS Camaro
Dec 15, 2014 05:59 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
