popping in front end when in 4 wheel drive?
Old Feb 1, 2013 | 01:30 PM
Kenneth Snider's Avatar
Default popping in front end when in 4 wheel drive?
i have 99 dodge 4x4 cummins my cusin has same truck when we put our trucks in four hi or four low and drive the front end make a loud pop noise and shakes the the truck. feels and sounds like its coming from driver side. we have already check and replaced the vacume actuator on the front diff. the poping isnt constant it just does when ever seen to do it more at 20mph. its not u -joint or wheel bearing. does anyone have some helpful info?
Old Feb 2, 2013 | 04:52 PM
Bryce's Avatar
That sounds like a u-joint to me. Did you check the drive shaft u-joints or just the axle joint?
Old Feb 9, 2013 | 11:21 PM
chummin89's Avatar
axle u joints, ball joints
Old Feb 10, 2013 | 09:17 AM
Al31031's Avatar
does it do it more when your turning?
Old Feb 10, 2013 | 12:53 PM
lunk's Avatar
tie rods can also do that when they go bad
shingi
Off Roading
Sep 30, 2015 11:17 AM
6.5dieselman
Feb 26, 2015 04:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
2002cabandchassis
Oct 29, 2014 01:59 PM
