02 cummins thought was ecu porb its not help
Old Jan 16, 2013 | 04:23 PM
silver02cummins's Avatar
Default 02 cummins thought was ecu porb its not help
have a 02 cummins about a year ago my ecu went out and replaced it worked fine now havin some of the same issues cutting out buckin white smoke sometimes black smoke others it started drivin home on the interstate in 5th cruzin it started cutting out just a sec and few seconds later agian for around twenty miles the next day it was worse dead petal white smoke ext replaced ecu agian and it didnt help it was used any sugestions it has edge comp box cold air and fass
havent checkd fp yet
Last edited by silver02cummins; Jan 16, 2013 at 04:23 PM. Reason: Automerged Doublepost
Old Jan 16, 2013 | 04:34 PM
Farmboy 2.0's Avatar
Id check lift pump pressure and are there any codes present?
Old Jan 16, 2013 | 05:38 PM
havent checked yet i forgot wat the codes wer when we scaned it its been sitting for a mounth tryd the ecu today it was worse tac iol press and temp gauges didt work the ecu was off a 99 truck
Old Jan 16, 2013 | 05:40 PM
Yeah they read differently than the later ones. I would see what codes are there and then lets us know
Old Jan 16, 2013 | 08:14 PM
found also coolant is seaping out of the passanger side in the front next to the ther housing but no fluid in the oil yet and its very so leak
will have codes tomorrow thanks
Last edited by silver02cummins; Jan 16, 2013 at 08:14 PM. Reason: Automerged Doublepost
Old Jan 17, 2013 | 09:04 PM
done the key trick to get codes mind you my ecm is not on the truck yet weather sucked here today pcm had `0122 0123 1693 still havent check fp bc ecu not on the truck yet apps ??
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
LittleBuck
23
May 21, 2015 06:06 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
