Lift pumps
Old Dec 4, 2012 | 08:36 PM
doggonebad's Avatar
Question Lift pumps
Could anyone of you tell me whether or not a bad lift pump will produce a readable code?
Old Dec 4, 2012 | 09:09 PM
South Texas Goat's Avatar
My 98 never gave a code until I had to give bosch $3000 , my 05 never gave me a code. Just started acting funny. Best thing to do is check the pressure, mine was down to 9 lbs injector pump over heats, spend to much money.
Old Dec 5, 2012 | 11:27 AM
VTstrokin's Avatar
The first signs you'll see is a random drop in boost, in the upper rpm's, it might seem like the truck is "laying down". Like South Texas Goat said, check your fuel pressure at the rear of the filter, it should be around 15. Best way to tell though is after changing the fuel filter, it will struggle to get fuel back to the engine.
Hope that helps some.
landon025
Sep 8, 2015 09:21 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
Callmecowboy
18
Feb 3, 2015 09:01 PM
Callmecowboy
Jan 22, 2015 04:39 PM
