03 hard to start when cold
Old Dec 4, 2012 | 12:59 PM
ojpearce05's Avatar
Default 03 hard to start when cold
I have a 03 3500 and when it is cold the first start if the day it spins over for a little while before it cranks. After that it is good to go. No smoke. Could that be injectors, glow plugs(or does it have them)? It does have 275,000 miles on it. Pretty sure they are stock injectors. And ideas? Thanks
Old Dec 4, 2012 | 01:15 PM
1999stroker's Avatar
Dodges don't have glow plugs,they have grid heaters
Old Dec 4, 2012 | 03:41 PM
lunk's Avatar
my did that it turned out the batteries where weak tried charging them it would crank just not fast so put in fresh batteries and fires right up no matter how cold it gets
Old Dec 6, 2012 | 08:27 AM
rlc34540's Avatar
You might get the injectors tested. My truck started having probelms with starting in the cold, after replacing almost everything it turned out to be the injectors.
Old Dec 8, 2012 | 10:33 PM
ojpearce05's Avatar
Thanks for the replies. After posting this it seems to be doing good. Just in case there something wrong with the injectors, where is the best and cheapest place to buy? Thanks again
Old Dec 8, 2012 | 11:18 PM
jkidd1's Avatar
with that many miles you may want to replace injectors.
you can get them tested for as little as $10 each. Some computers can check contribution rates without removing the injectors.
Old Dec 11, 2012 | 10:04 PM
ojpearce05's Avatar
Would injectors make the motor really noisy when cold? I guess you call it injector knock. Where is the best place to get a new set or rebuilt injectors?
Old Dec 11, 2012 | 10:48 PM
Check out our sponsors.post in the request a price quote section
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
custom7.3
Nov 23, 2014 10:44 PM
