6.2 diesel in an s10???
Old Oct 16, 2012 | 08:26 PM
smokincummins92's Avatar
Default 6.2 diesel in an s10???
I want to do this! I havnt been able to find much info on swaping a 6.2 in an s10 but I know it has been done! Im just curious as to what needs to be done with the motor mounts and how well the rear end will do. I have a 87 s10 with a 2.8 auto 2wd
Old Oct 17, 2012 | 09:23 PM
cumminsf150's Avatar
build the motor mounts, try the rear end, if it dosent work get a narrow 8.8 out of an explorer, and wait for the haters
Old Jan 23, 2013 | 04:18 PM
billy0222's Avatar
the 6.2 mounts just like a sbc, so any sbc mounts would bolt the engine straight to the frame, just watch your bellhousing a lot of 6.2's used the Buick, Olds, pontiac bellhousing
Old Jan 23, 2013 | 09:13 PM
BarryB's Avatar
There is a thread over on s10 forum. The guy installed a 6.5 in his s10 then later installed a duramax in it. pretty awesome build.
here it is, long thread. http://www.s10forum.com/forum/f221/its-alive-340611/
Old Jan 25, 2013 | 12:28 PM
HALFLIT's Avatar
Just install a duramax
Old Jan 28, 2013 | 10:01 AM
Colby Ritter's Avatar
I'm looking at doing the same thing I have a 94 4x4 s10. Wanna put the 6.2 in it the rear end should hold Chevy trannys all bolt up right? Or is it a smaller tranny on the 4.3 v 6 ?
Old Jan 30, 2013 | 01:51 PM
thumpertrev's Avatar
These pics show most stages from stock to 350 chevy to finally a 6.5 turbo.
Old Jan 31, 2013 | 12:18 AM
DieselS10's Avatar
OP, it can fit, but be aware that it won't fall in there like a SBC does. Plan on removing most of the cross-member below the engine, swap to hydro-boost, extensive core support mods to accept a large enough radiator and to move it far enough forward to fit the stock EDF. SBC mounts will not work, the passenger motor mount will need to be moved several inches forward to clear the starter. Van injectors help from what I've read due to them being shorter and expect there to be a little interference at the upper A-arms and the steering shaft as well. Oh and the HVAC will need to be modified for clearance.
Colby Ritter, pretty much all of that will apply to you as well except the cross-member under the engine. You will have issues clearing the front axle/diff, but not the upper A-arms.
This engine is considerably larger than it looks in the full-size trucks, it is nowhere near the same size as a SBC and is quit a bit wider than a BBC. It will go in there with the sheet metal all in stock locations, but it is a lot of work. Having had a 6.5TD installed in mine for a couple of years, I can say that I would do it again.
Old Jan 31, 2013 | 08:46 AM
Diesels10 is correct on everything. The only difference in my build was that I used a stock heavy duty 4.3 radiator fulling expecting to need a bigger one but, I never had any trouble. even in traffic it stayed cool. The 6.2 and 6.5 use a Chevy bolt pattern on the trans. The old 5.7 diesels used the BOP pattern. I used a stock rebuilt 700r4 with a diesel governor swapped for the shift points. Its a great combo that I would still own if I didn't need a bigger truck.
Jackthesmallengineguy
Nov 12, 2017 01:25 PM
NSmachine44
Aug 16, 2015 09:25 PM
Finn92
Jan 16, 2015 09:46 PM
Chris Thompson
For Sale
Jan 7, 2015 07:02 PM
joealto91
Dec 8, 2014 06:54 PM
