2g lift pump regulator question
Old Oct 16, 2012 | 10:16 AM
B430's Avatar
Default 2g lift pump regulator question
In the threads I've read it seems people are using boost referenced regulators, this seems to me like it would be incorrect for this application. Am I looking at this wrong? If you set to 15psi then add 30psi of boost then your fuel pressure would be 45psi would it not?
Old Oct 17, 2012 | 12:23 AM
1stgenblowingsmoke's Avatar
Don't get a boost regulated regulator. just get a regular 9-12 psi adjustable regulator.
I had one on my old VE engine.
Old Oct 17, 2012 | 12:31 AM
B430's Avatar
The one I got has a boost reference, but I'll just leave it unhooked.
Old Oct 17, 2012 | 01:43 AM
Get a fuel pressure gauge if that pressure goes above like 17psi I think you can blow out the front pump seal.
Old Oct 17, 2012 | 09:04 AM
B430's Avatar
Fuel pressure gauge is among the goodies I'm waiting to get delivered.
Old Oct 18, 2012 | 12:41 AM
Right on I'm waiting on my snubber valve from Genos and two overflow valves from larryb's.
Old Oct 18, 2012 | 03:44 AM
B430's Avatar
I'm waiting on cab mounts, leaf spring bushings, a few gauges, a fuel regulator, governor spring, 60mm compressor, and some silicone couplers. Gonna be busy when everything comes in.
Old Oct 18, 2012 | 01:59 PM
Wish I had that kinda money. i want mine to be able to roast 1st through 4th gear one day.
Old Oct 18, 2012 | 02:46 PM
B430's Avatar
Well, if it makes you feel better I don't have that kinda money anymore .
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
