Runs fine for an hour or two...then..
Old Oct 8, 2012 | 10:24 AM
farmingsthelife's Avatar
Default Runs fine for an hour or two...then..
Hey guys I need some help. My truck was having typical cps symptoms. I replaced the sensor and then things started getting weird. Now, it can be idling, running on the highway, etc etc, and just die like a cam sensor failure, except everything electric (dash, clock, lights) won't work and the key acts like it does nothing. Let it sit for 2 or so minutes it starts right up......any ideas?
Old Oct 8, 2012 | 01:37 PM
CSIPSD's Avatar
Check the battery connections...
Old Oct 8, 2012 | 06:12 PM
That was the first thing I checked. No corrosion and they Are all tight...but idk about grounds, and where the power cables go etc etc. it's amazing I can do hpops, turbos, injectors, but this
Little stuff dumbfounds me
Bump-after work I came home to mess with the truck. Went to start it up, cranked for maybe 5 or 6 seconds and then I lost everything again. This time I heard a clicking noise under the dash. Pulled the fuse panel off and I could hear the relay in the top right corner (in the box under the dash, not the hood) clicking its mind out. It's a part number f57b-14b192-aa8003a32d. Anyone have any ideas? I'd really appreciate help.
Last edited by farmingsthelife; Oct 8, 2012 at 06:12 PM. Reason: Automerged Doublepost
Old Oct 8, 2012 | 06:32 PM
CSIPSD's Avatar
Do you have an amp or volts gauge? It almost sounds like your batterys are dead/low or your alt is not working...
There is a ground on the passanger fire wall, one behind the motor, one under the motor...
Old Oct 8, 2012 | 07:02 PM
Had one bad ground, and a few bad fuses. Replaced them all and the truck would crank but not start (at least now I had something to work with) and when it would start it would run a few seconds and die. Beings I just replaced the cps (looks like in vein) I unplugged the icp sensor. Ran like a champ. So it's looking like I have to replace that too. I just wonder if there was a voltage spike or something that could have done all this. Sure is weird all this happening at once.
Old Oct 8, 2012 | 08:15 PM
CSIPSD's Avatar
Odd that the ICP sensor is keeping it from running... Have you driven it since you unplugged the ICP?
Sounds to me like you have a ground issue somewhere, I dont think there is a spike issue.
Old Oct 9, 2012 | 08:21 PM
Drives with the icp unplugged. Plugged it up and it surges at idle or won't run at all for more than 3 or 4 seconds
I managed to snag a known good icp sensor from work this morning. I guess I'll try this and pray that it helps. I don't wanna go chasing at a wiring war really badly. Would a fried uvch cause one to just stop running intermittentenly?
What's got me confused it how it runs exactly normal with the icp sensor unplugged.
update-Finally got the truck running long enough to get it inside the shop at home and take a look at what was going on. I plugged the icp sensor in and it seemed to run fine..but then it died again. So I unplugged it...and it started up but ran very rough...so I was looking around the engine for a exposed wire or something and I gently touched the uvch and it just slid off...the connector was broken. Any chance at all it could have been vibrating on and off while driving giving me my cps-like symptoms?
Last edited by farmingsthelife; Oct 9, 2012 at 08:21 PM. Reason: Automerged Doublepost
bdbfam
Aug 31, 2015 09:06 PM
Freezzman
Jul 6, 2015 03:01 PM
petew
Jun 2, 2015 07:33 AM
Rbear
May 3, 2015 07:47 PM
dandbmcc
Mar 14, 2015 11:05 PM
