Homemade down pipe question
Old Oct 7, 2012 | 12:11 PM
B430's Avatar
Default Homemade down pipe question
i made a 4" exhaust running to a single 5" stack, but I used the stock 3" elbow off the turbo. Is this going to cause a restriction with the stock turbo? I've been on the fence since I finished it wondering if I should change it to a 4" elbow or wait until I get a bigger turbo, likely in the spring since I'll need to modify it then anyway.
Some pics, there are no cab mounts in right now so it will have a bit more clearance than there is now.
Old Oct 7, 2012 | 01:13 PM
bladeyamaha's Avatar
Nice work!
I want to make one out of 6 inch for kicks or have one made out of 6 inch pipe.
Last edited by bladeyamaha; Oct 7, 2012 at 01:13 PM. Reason: Automerged Doublepost
Old Oct 7, 2012 | 01:54 PM
BC847's Avatar
The 3" to 4" transition you've got there should work just fine seeing as the turbos outlet is 3".
I'd be more concerned about stress put on the turbo's flange with with the weight of the exhaust plumbing and the normal vibration & twisting of the engine with normal operation. That's why Dodge attached the stock/OEM down-pipe to the trans bell-housing . . . to take that stress off the turbo flange.
Old Oct 7, 2012 | 02:42 PM
B430's Avatar
I will be attaching the exhaust to the frame with exhaust hangers once everything is complete.
My concern is the elbow is not actually 3" more like 3x2" due to the way it is bent.
Old Oct 7, 2012 | 03:07 PM
Yeah.
Old Oct 7, 2012 | 06:32 PM
BC847's Avatar
Good luck.
Old Oct 13, 2012 | 10:38 PM
B430's Avatar
Decided to change it out for a 4" elbow, much happier with it now:
Old Oct 14, 2012 | 01:15 AM
Nice, it will help, I believe, it will have some restriction but there is almost nothing you can do about the exit flange size. LOL It looks great man.
Old Oct 14, 2012 | 03:22 AM
B430's Avatar
Well my thought is that is pretty much the least restrictive exhaust I can do other than a hood stack, so I'm satisfied knowing I did the best I can practically do.
Also if I upgrade to a turbo with a 4" outlet it's a simple cut and weld to change it from 3 to 4".
Old Nov 15, 2012 | 05:24 AM
I found all the stuff I need to do a 5 inch DP and intermediate pipe and Y pipe with 90 degree elbows and 45's off eBay and plan to make my exhaust setup by the end of spring, the DP, intermediate pipe, to the completed Y pipe will cost a little under $400 to make Should be $380 by the time I'm done or less, possibly. Looking good to me.
5 Inches the whole way.
Last edited by bladeyamaha; Nov 15, 2012 at 05:24 AM. Reason: Automerged Doublepost
PowerstrokeDepew
99-03 7.3L Performance
May 5, 2016 08:12 PM
Devon7.3
Sep 28, 2015 09:30 PM
Blake35
Jul 25, 2015 03:44 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
