6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Fuel system thoughts
Old Sep 6, 2012 | 10:04 PM
SuperBlazin's Avatar
Default Fuel system thoughts
Ording a fuel system from dozerz and am wondering what y'all think
-sinister sump to
- areomotive marine a 1100 to
- areomotive 10 micron inline filter. To
- dozerz stage 3 regulated return
Old Sep 7, 2012 | 07:30 AM
Mdub707's Avatar
If you read the A1000 manual, it says it's "OK" to run just that pump, IF the fuel feeding it is higher than the pump, which you'll see even with the sump is going to be very hard to accomplish without mounting your pump below the frame. They recommend a pusher pump to feed it, something like an AD150. Fuel lab also makes a good pump as an alternative to the A1000.
Other than that, it sounds good! You already have a fuel pressure gauge?
Old Sep 25, 2012 | 03:00 PM
g2shuck's Avatar
I run an XDP sump, Airdog 150 low pressure pusher pump, and custom regulated return with fuel bowl delete all made from -4AN aluminum fittings and -4AN braided stainless steel hose. I will soon be removing the HFCM and installing and aeromotive a1000 with aeromotive billet speed controller. This combo will support injecters bigger than what the HPOP can support. Lets just say I have talked with bill at dieselsite and I am going to have to run athe adrenaline HPOP with double HPOP lines to support my future injectors but the fuel system I just listed will support the fuel needs of the injectors at full fuel.
Old Oct 1, 2012 | 02:34 PM
Mdub707's Avatar
and a built trans, and a bigger turbo/s and so on and so on hahahaha. What size sticks are you looking at? At that point I'd scrap all the high pressure oil ideas and just go with hybrid injectors, but that's me!
Old Oct 28, 2012 | 02:49 PM
monster12valve's Avatar
I was thinking... Sump....10micron filter... Ppe lift pump.....10 micron filter.... Fuelab prodigy fuel pump.... Then a RR . That should be a solid setup? Should be plenty of fuel for 205 or 225 correct?
Old Oct 28, 2012 | 03:01 PM
Going with the Helmans sump- fuel lab 150/150 - regulated return with fuel bowl delete.
Your correct I'm going with 205/100 injectors
Old Oct 30, 2012 | 02:03 PM
Mdub707's Avatar
Why do two separate 10 micron filters? Just do the Fass or AD 150 and call it a day, it has built in filtration and is a lift pump.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
