- NV4500 shafts
- turbo kit
- Torque converter for 48re
- 2000 cummins and 67 mustang trade
- quad adrenaline w/pulse monitor
- looking for quadzilla adrenaline or edge comp for 24v cummins
- 12v head
- used or new triple disk 47re
- 99 powertrokes trans parts
- Looking to Buy CDR valve
- Programmer for 2000 dodge
- WTB Duramax
- MAYDAY
- Chevy or GMC crew cab cummins
- 14cm turbine housing for a HX40 pro
- Anyone have a HX40 14cm gated turbine housing
- Looking for 1st gen. Cummins
- H1C Turbo
- Looking for a 5-speed swap for my 96 Dodge 3500
- 92-97 Ford 4x4 Shifter Bracket
- NV4500 HD
- need pcm for a 97 auto
- 1996 F350 4X4 Front Hub & Spindle
- steel wheels
- edge comp map sensor connectors
- stock turbo oil return
- dodge tow mirrors.
- aftermarket lift pump
- Quad Cab
- need a bracket
- bullydog pyro thermocouple fried. need new one.
- looking for auto to manual parts
- Nitto Terra Grapplers
- 2000 F250
- WTB: 94-95 Dodge 47RH 4x4
- Hypermax mounting Kit
- 4:10 gears
- looking for turbo kit banks sidewinder!!
- 2000 dodge auto pcm
- HX35
- 4x4 1st gen parts
- pulse v2 98.5-02
- ford fender flares
- looking for alot of stuff check it out
- Hx50
- Urgently in need of good used vp44
- WTB 4BT AIR CROSSOVER PIPE
- super b special
- 4x4 parts off 1st gen
- '03-7 PSD Cat
- 2000 24V ECM
- Autometer 2249 boost 30psi sending unit
- Ve injector lines
- 1998 24v ecm needed
- WTB: aftermarket lift pump
- edge comp and/or smarty for 01 cummins
- Wtb factory ford navigation/radio
- injectors an turbo
- WTB: Used Dodge flex-a-lite fans(#264)
- 12 valve injectors
- 99 Powerstroke intercooler
- non gated hx35 or maybe hx40 hybrid
- WTB stock 2nd gen manifold.
- 3" to 4" Exhaust Flange
- looking for a H1c turbo
- Trans cooler
- headliner for 91 d250
- looking for a few parts for a 91 d250
- 3.9 diesel
- 2nd gen dodge ranch hand bumper in az?
- WTB: In INDIANA tires or wheels and tires
- Detroit 53 series Jakes
- 6.7 cummins motor
- needing a hx35 or hy35 for my 12v
- 5K gov springs
- wanted nav,2003
- 1994-early1998
- wtb he351 vgt
- cummins 12v block heater
- hx40 or similar
- WTB 6.0,7.3,cr Cummins and duramax inj cores
- WTB 94 thru 02 DODGE DANA 60 FRONT AXLE 4:10 GEARS
- Looking for CR cummins SRW
- WTB: cheaper chip/ tuner 05 dmax
- 2000 ram 2500 dana 80 rear 3.55
- Ford Dana 80 3:73 ring & pinion set
- wtb 24v cummins.
- WTB: 98-04.5 APPS TPS sensor for cummins
- p7100 pump timing pin
- 1st or 2nd Gen
- 1993 ext cab jump seats
- hx35/40 hybrid
- 97-98 stick 215 injectors.
- D60 right side pumpkin front Axle
- Motor Mounts
- fuel tank
- power wagon 1950
- WTB Turbo (H1C, HX35, or similar)
- lookin to trade.
- wtb replacement front end.
- WTB or Trade for first gen auto
- Trans for 89 1st gen
- Head
- dodge flip out tow mirros
- 03 VGT
- 03-04 cr motor.
- t3 manifold spacer
- couple things
- 07 Injectors and 01-02 3500 axle with 4.10 gear
- WTB: USED injector nozzles 90hp 03 CTD
- WTB: Smarty or Juice for 01 cummins
- rebuildable 6.7 cummins
- WTB 01 ram drivers side seat maybe other years!
- WTB a NV5600
- WTB: Dodge 3500 Computer P56040504AC
- Aftermarket Lift Pump!!!!
- Stack Y pipe and clamps
- 1998 engine wiring
- wtb: he351 turbo
- WTB: Holset HX35 exhaust flange elbow
- silver bullet 66
- dana 70 3.73 gears or dana 60 3.54 gears
- need a set of injectors 100 to 150
- Wanna trade rear ends?
- WTB chevy 6.2/6.5 parts
- parnelli jones dirt grips and/or mickey thompson wheels
- wanted dodge w350 4x4 diesel w/5 speed nv4500
- WTB Enclosed cargo trailer
- 12valve head
- OBS Ford winch bumper
- WTB so vp44
- hx40
- VGT Coolant lines
- Smarty
- WANTED: 1st Gen Regular Cab 5spd 4X4
- Looking For a 2gen Cummins in NY
- WTB: Bully Dog
- transfer case!!
- a/c compesser
- quadzilla adrenaline pv2 asap
- Looking for k5 blazer/jimmy 1987-1991
- Dpf systems
- 1st Gen 2wd auto
- getrag?
- need 4 door 4x4 cummins manual trans
- Tires and Rims.
- 3 peice manifold and turbo
- Rok Crank Sensor
- holset hx 35 12cm exhaust housing
- need parts for getrag transfer case
- WTB NP 241 DHD
- All DPF systems. Top prices paid
- WTB: HY35, HE341 Turbo
- 89-93 Dodge SRW Dana 70 Rear Axle-Northern California
- Dodge 24 valve HVAC Controls with heated mirror button
- Used 2WD 2500 or 3500 Crew Cab
- triple Dog
- Long bed swap, DRW going to SRW
- First Gen Dodge Ram Cummins Diesel near DC
- wtb edge comp 02 dodge
- nv4500
- 64 or 66mm turbo
- wtb 01-02 2 gen sport bumper
- Ford F350 Dana 60 Parts
- WTB Aux Tank/Toolbox combo
- WTB 2nd Gen Lift Kit
- WTB- stock steel wheels 1991 w250
- Wanted: Dodge 07.5 and newer DPF exhaust
- 01 hood......
- 2002 front bumper, rally wheels
- HE351VE
- hx35
- Stock aluminum 3rd gen wheels
- Looking for some used guages
- Need radiator
- 45re case needed
- sterling bullet grill
- Looking for 06-newer commonrail cummins
- need p pump
- 94-02 Ram parts
- GET PAID - FINDERS FEE - Looking for Dodge Truck
- crank shaft sensor and connector tube o rings
- 04.5-07 exhaust elbow
- Need HX30/35 compressor outlet elbow, and oil drain.
- Wanted: Speedometer clear cover and gear shift selector cable
- PLEASE HELP
- 6in air filter
- 6 pos chip
- needed fuel line
- WTB: AIRDOG/FASS
- WTB Stock 3" muffler
- nv4500 4x4 or other parts
- Need VE injectors
- Ram 3500 club cab (cab only)
- ECMs
- trade 05 honda 450 for 12v or 24v
- 4bt Cummins
- Chip for a 99 5.9L
- WTB:Hay
- i need a turbo!!
- WTB stock shift boot
- used smarty s-03
- Stocker Turbos
- WTB Camper Shell For 03-08 Dodge Short bed..
- Dip Stick Tube
- 6.7 cummins intake manifold
- Edge comp, 4" hx40 down pipe
- WTB Stock Air box and pipeing for a duramax 03
- wtb:k5 blazer
- 02 edge comp adapters
- 12v needed
- CAT STACK
- wanting 47rh core, or working
- mbz turbo diesel stuffs and things.
- smarty for 98.5-02 cummins
- looking for bumper
- wanted: 215 p-pump...
- Fan clutch and fan
- WTB turbo
- 6.7 exhaust manifold
- 4 fog/driving lights
- need a sport front bumper
- Twin Ram for 12v
- i need a 12,24, common rail engine
- 2nd Gen Center Cap
- need parts bad
- i need a turbo
- 99 cummins chip
- 2002 Dodge Front driveshaft
- 98.5-00 cummins EJWA or COMP
- fuel and rail pressure gauge
- cummins turbo/intercooler elbow
- WANTED, 89-93 Dodge Ram Diesel, in Decent or Good Shape.
- coolant line needed
- Want 4.10 Gears for Dana 60 & 70
- methanol
- WTB Upper control arm 2wd
- Ranch Hand
- 373's
- 6.7l turbo
- Gauges
- wtb
- WTB: 47re Lockup controller (ATS Copilot, etc)
- Need 35in tires
- first gen bed
- hx35
- WANTED: 97-98 Dodge 3500 5spd Cummins 12-Valve Dually
- 1st gen auto trans ? Or complete roller
- WTB 4x4 truck diesel a plus
- want 48re built tranny!!!!!!!!!!
