fuel pump module
Old 06-26-2016, 10:42 AM
LDOYLE's Avatar
It looks like there is a slot it slides up in but can`t tell how it locks in . Maybe the new one will help me understand .
Cant tell how to get to the wires ( connection on top) to unhook them
  #12
Old 06-27-2016, 03:36 AM
Jet A Fuel's Avatar
Yes it definitely looks like it slides up the slot , I bet when you get the new one it will be easy to tell whats up with both issues. It may be a wedge fit also might have to use a mirror and look for a lock tab in the slot. Tap it down see if it moves. It looks like the rheostat circuit card is held in with little tabs too.
If there isn't a plug with the new sender you may have to disengage the wire with a red and white plastic wire extractor (available at radio shack).
The metal connectors on the end of the wires have a small tang that locks the connector to the plug.
  #13
Old 06-27-2016, 06:30 AM
LDOYLE's Avatar
Thank you Jet A Fuel for your help . When I finish I will repost results
  #14
Old 06-27-2016, 01:41 PM
LDOYLE's Avatar
Yes , there was a tiny little tab that locks it in place . Slight pressure with a screwdriver and it comes out . One problem solved . Now to figure out how to get the wires unhooked . I see a push tab on bottom of lid connector but haven`t had any luck yet . I push and wiggle everything but nothing yet .
  #15
Old 06-30-2016, 04:14 AM
gh0stman's Avatar
If adding a draw straw make sure your cut is straight. If not you will end up with 1/4 fueling issues.
  #16
Old 07-01-2016, 01:34 AM
Jet A Fuel's Avatar
Good suggestion Ghost! the instructions say to use a quarter and space it off the bottom of the tank. The problem I found is when the tank expands and contracts this gap can be greater or less with fuel load/tank pressure etc. Less gap would be bad cause it could restrict the flow if the bottom of the tank comes in contact with a straight cut straw. To fix this possible scenario I cut mine like this.
This has worked good for me
  #17
Old 07-01-2016, 06:38 AM
gh0stman's Avatar
I've always heard 2 quarters. But the most important thing is a straight cut on the low end.
  #18
Old 07-01-2016, 11:01 AM
LDOYLE's Avatar
UPDATE : Everything is back together now and on the road again . I`m happy and thanks for the replies guys .
The following users liked this post:
Jet A Fuel (07-01-2016)
  #19
Old 07-02-2016, 08:07 AM
gh0stman's Avatar
Good to hear. Hope it does you right.
