03 7.3 stalling out??
Old Jul 30, 2012 | 11:59 AM
Lange503's Avatar
Default 03 7.3 stalling out??
mods are in my sig. when i go to start out from a dead stop it will either try and stall out or completely die like you are letting the clutch out too fast on a standard, and mine is an auto, i've replaced the entire pedal and sensor, what else could it be? and it is also not throwing any codes, i do have a oil leak on my high pressure oil system somewhere, could that be the issue?? any input is appreciated, thanks
Old Jul 30, 2012 | 01:43 PM
CSIPSD's Avatar
Check the CPS wiring, Clean, possibly replace the ICP sensor (assuming this is your leak?)... Check your IPR and wiring.
Old Jul 30, 2012 | 03:45 PM
Lange503's Avatar
i'm not sure where the leak is just yet, but i will check all of that, thanks
Old Aug 22, 2012 | 11:46 AM
Lange503's Avatar
on the scan tool that i have all i can look at is the voltage to the icp and the duty cycle, what should the duty cycle be at? and also the voltage??
Browe347
Dec 11, 2016 02:59 PM
Toms73
Mar 23, 2015 08:31 PM
tumble72
8
Nov 27, 2014 10:31 PM
Altonlee
9
Oct 8, 2014 02:31 PM
Browe347
Sep 30, 2014 11:35 PM
