4L80E problem
Old Jul 23, 2012 | 05:05 PM
steelmanpdx's Avatar
Default 4L80E problem
my trans won't stay out of passing gear. any ideas?
Old Jul 26, 2012 | 02:25 AM
cviola2005's Avatar
do you mean that it acts like it shifts into OD but when you touch the gas again, it kicks out? or you don't have OD at all? can you describe in better detail please?
Old Jul 26, 2012 | 04:08 PM
kicks out when touch throttle
Old Jul 27, 2012 | 11:45 AM
cviola2005's Avatar
what kind of vehicle? mechanical or electronic injection pump? is the check engine light on? if so, what are the codes.
my trans had the same problem when i got it. PCM picked up slipped in 4th gear and defaulted to no OD. It also shifted at 2500 rpm from both 1st and 2nd. Also it wouldnt kickdown when I stepped on it, once it got to 3rd, it stayed there until I came to a stop.
Does this sound like you problem?
Old Jul 27, 2012 | 01:26 PM
no, mine is 93 k2500 mech ip, shifts through all 4 gears, then when i let off throttle i get another "shift" up, i'm thinking torque converter isn't locking, because when i touch the throttle again to maintain speed it "shifts down", unlocks? and doesn't shift up "lock" until i let off the throttle again
i have no tach
Last edited by steelmanpdx; Jul 27, 2012 at 01:26 PM. Reason: Automerged Doublepost
Old Jul 29, 2012 | 11:08 AM
cviola2005's Avatar
I read that the torque converter lockup "hunts" for the perfect conditions to lockup, and that it doesn't take much for it to unlock. You'd have to go with an aftermarket controller or a manual switch to keep it locked up.
Old Jul 29, 2012 | 07:37 PM
ebarresi5894's Avatar
I have manual switch for TCC Lock. Usually torque converter only locks in OD
Old Aug 13, 2012 | 08:16 AM
leatherwood's Avatar
My 4l80 is doing what you just described. I just got the 93 chevy 3500 and have not checked the problem yet. What was the fix for yours?
Old Aug 13, 2012 | 01:38 PM
cviola2005's Avatar
every time it would kick out of OD and wouldn't go back in, i pulled over and unplugged the trans computer for about a minute, plug it back and i was good to go. its not really fixed, I ust take it easy when its in OD and it usually doesnt kick again.
Old Aug 19, 2012 | 02:27 PM
i think i'm going to put in a mech switch
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Irish_Alley
Jun 21, 2015 12:04 AM
Irish_Alley
Nov 28, 2014 12:57 AM
