Starter Fix On The Cheap
Old Jul 23, 2012 | 05:00 PM
steelmanpdx's Avatar
Default Starter Fix On The Cheap
Attachment 24990
Attachment 24991
Attachment 24992
Attachment 24993
Attachment 24994
Attachment 24995
for those of you that cannot afford a new block when the outer starter bolthole breaks, here are some pics of my cheap fix
Old Jul 26, 2012 | 02:23 AM
cviola2005's Avatar
links arent working
Old Jul 26, 2012 | 02:43 PM
Mayhem's Avatar
Attachment Fail
BY the way if anyone need a starter brace for a direct drive starter P.M. me and I can give you the mesurements and angle to make a good and sturdy brace being that G.M. has dicontinued the orriginal one
Old Jul 26, 2012 | 04:18 PM
you can get the original from dsu peterbuilt
i don't know what's wrong with my links to the pics
basically i lengthened the tail brace to within 1/4 inch of the pan rail and put a bolt through as a spacer against the block so it's not hanging in the breeze.
then i cut a piece of 1/4 x 1 flat to span the starter bolts and stick out passed to directly below the top splash pan bolt, replaced the bolt with a eye-bolt and dropped a j-bolt through and sucked it up tight
Last edited by steelmanpdx; Jul 26, 2012 at 04:18 PM. Reason: Automerged Doublepost
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
