vacuum line to injection pump?????
Old Jul 18, 2012 | 11:27 AM
corvetteguy's Avatar
Default vacuum line to injection pump?????
I am in the process of swapping a 84 6.2 into a 86 gasser. while digging around the engine labeling stuff for the swap i see there is a vacuum line from the vacuum pump that goes to some device that is attached to the injection pump. opposite side of the throttle then the line exits the device through a port just under the inlet and as far as i can tell it goes to the automatic transmission.
What is said device and what is its function?
Old Jul 19, 2012 | 01:03 PM
cviola2005's Avatar
i dont see why it would go to the injection pump, but if it goes to the trand then it is for vacuum modulation
Old Jul 23, 2012 | 10:54 PM
I will try to post a picture tomorrow maybe someone will recognize it.
Along with the device, If I am bolting a 6.2L to a manual transmission do I even need the vacuum pump? Is there any accessories that run off of vacuum on an 86 3/4 ton.
Old Jul 25, 2012 | 10:36 AM
Default A picture
okay in the attached picture I cicrcled the device in red. I know the vacuum line goes to the trans. that makes sense( thanks anyway cviola2005), but why is it routed through the device attached to the IP?
Old Jul 25, 2012 | 06:10 PM
Mayhem's Avatar
I belive it is kinda like a primative throttle position sensor type thing to let the trans know when to shift?
Old Jul 25, 2012 | 06:34 PM
Okay thats makes sense. Is there any function other that auto trans shifting. Since this motor will get bolted up to a manual is why I ask. Is it even present on manual trans 6.2's.
Old Jul 25, 2012 | 06:43 PM
tyty's Avatar
Default tires
I was wanting to know if anybody could help me own an issue im having. I have a 04 f250 with the stock rims and the tires are 285/75/16 with bf all Terran tires. does anybody know what is the biggest rim and tire and offset i could go to with out putting a leveling kit or lifting my truck up. if you have pic that would help further thanks
Old Jul 27, 2012 | 02:32 PM
Mayhem's Avatar
Try this site here it will point you in the right direction
Tire size calculator
Old Aug 5, 2012 | 08:50 PM
bhammemtp's Avatar
I am now a owner of 6.5L Turbo Diesel. The truck runs great but I have noticed that I only hear a faint turbo whistle for time to time. I have been doing some research online about the 6.5 Diesel's and still have a few questions if anyone would like to help me out.
I have found that the wastegate valve has a port for a vacuum line but I can not find any unattached lines. Where does it get the vacuum from? I have checked the turbo shaft and it is spins free & is tight. Any thoughts??
Old Aug 5, 2012 | 09:18 PM
Mayhem's Avatar
Vachuum is made by the vavhuum pump on the located lower passenger side of the engine
ctjkelley
Jun 3, 2015 06:01 AM
DeLuzGN
Mar 17, 2015 08:08 AM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
