6.7 Fuel filter change?
Old Jul 16, 2012 | 07:43 PM
skirk55's Avatar
Default 6.7 Fuel filter change?
I have a 2011 6.7 diesel and it is time to change thefuel filter. Is it hard to do?
Old Jul 19, 2012 | 02:04 PM
Grrrr's Avatar
nope!
Old Jul 20, 2012 | 10:07 PM
Dude_57's Avatar
I'm pretty sure it's just like the old 24 valve get a weather stick the rn of it in the top take lid off pull off old filter and snap one in and put back in I'm doing mine tomorrow
Old Aug 9, 2012 | 10:15 AM
m.wooten's Avatar
do you have to fill the canister with diesel before you screw it back in. I was told you have to but its a pain in the ****.
Old Aug 9, 2012 | 01:31 PM
Grrrr's Avatar
no....its a self priming system. The diesel you pour into the canister is not filtered. Filling it first would allow unfiltered fuel into the engine....
You will just have to crank it a little bit, after you cycle the pump a few times with the key.
Old Aug 9, 2012 | 09:23 PM
m.wooten's Avatar
That makes sense thanks.
Old Aug 14, 2012 | 08:53 PM
07.5 cummins's Avatar
they are diffrent from the 5.9. the whole canister comes off from the bottom and pop the filter out put new in after you reinstall cycle the ignition a few times should prime
Old Aug 15, 2012 | 12:37 AM
cjt8569's Avatar
Nope 11/8 socket and spins right off...
Old Oct 2, 2012 | 03:35 PM
FreeseDiesel's Avatar
depends on your year. some are spin ons, some are 5.9 style. yours being an 11 is a 5.9 style. very very easy. 1 1/8 socket on a breaker bar, do not over tighten, and replace o ring every time.
of course if it was an 08, those are easy too, reach through the fender well cut out.
Old Dec 10, 2012 | 07:52 PM
Farmboy 91's Avatar
I have an 09 6.7 and when I take off in first or second the truck dies so should i change the fuel filter?
jeffersonl
Nov 15, 2015 07:35 PM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
