new re-built engine wont start
Old Jul 9, 2012 | 06:25 PM
jdwisdom's Avatar
Default new re-built engine wont start
I had my 2006 dodge 3500, cummins engine re-built, installed re-builted injectors, new injector tubes. Can't get the truck to start. I have fuel going to return, no fuel rail pressure. All tubes and injectors have been checked and re-checked. THINGS I HAVE DONE: had checked with scanner- not showing any codes, calls for 4800 lbs of pressure it has 49# of fuel pressure. removed new-rebuilt injectors and took to another shop and had tested. checked out good. got another set of injectors today and put in...still won't start! fuel is still going to return. checked pop-off valve, replaced crank sensor, What else can cause fuel to go to return.
Old Jul 9, 2012 | 06:36 PM
cummin_un_glued's Avatar
FormerVendor
swap the rail pressure relif valve and see if it makes a difference
Old Jul 9, 2012 | 07:41 PM
jdwisdom's Avatar
I took the line off of the relief valve and no fuel coming through it. Is this what you mean?
Old Jul 9, 2012 | 09:59 PM
FormerVendor
good enough yes thats what i was getting at was a bad fprf
Old Jul 12, 2012 | 06:54 PM
jdwisdom's Avatar
Replaced pump and it started. The pump was working when I removed motor...don't know why it didn't work after I installed new re-built motor.
Old Jul 12, 2012 | 08:03 PM
FormerVendor
i bet it was just the FCA
Old Jul 17, 2012 | 01:38 PM
mmanderf's Avatar
How much did your engine cost to put in?
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
mcclusk
Feb 21, 2015 09:50 PM
Austin Rathbun
Dec 11, 2014 03:49 AM
bajahigh
Dec 9, 2014 03:46 PM
