6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Edge cts insight or gauge pod
Old Jul 6, 2012 | 04:50 PM
Jay c's Avatar
Default Edge cts insight or gauge pod
I can't decide which would be the best and easiest. I would like to have egts, fuel pressure, ect, and more any opinions
Old Jul 6, 2012 | 04:58 PM
RAW's Avatar
RAW
I put the Insight CS into my work truck, and it works well. Took some extra money and time to get the Pyro in, but I am happy that I did.
Old Jul 6, 2012 | 05:14 PM
Jay c's Avatar
Are you happy with the setup of it is it worth the cost
Old Jul 6, 2012 | 05:52 PM
RAW's Avatar
RAW
I think it is very much worth the cost. In this case, too much information is better then not enough. I watch Trans Temp, EGT, Engine Oil Temp, Engine Coolant Temp, ICP Pressure, Boost, FICM Voltage, and Battery Voltage all at the same time. All things that I think are critical for these trucks. Mine is in a 2006 F550 service truck that weighs in at close to 17,000lbs.
Old Jul 7, 2012 | 09:26 AM
Mdub707's Avatar
I've got gauge pods in my truck, I liked the stand-alone gauges. The pods basically only read whatever the PCM is already reading, so to me it just seemed redundant, though not all readings are like this obviously (fuel pressure, egt's etc).
I still contemplate going to a CTS or similar though... they are nice units and clean up the cab nicely if you've got a slew of gauges. I will probably be going with the PHP Gryphon anyways for FICM tuning, and that can do a lot of those readings too.
Old Jul 9, 2012 | 06:39 PM
Lilpooh's Avatar
If you have a iOS device (iTouch/iPad/iPhone), check out DashBoss. It will monitor everything right on the iOS device, including EGT and Fuel psi. Total cost is $300. That's half the cost of a Edge CTS with EGT and fuel psi. And about the same cost for a ScangaugeII with separate analog EGT and Fuel psi.
Old Jul 9, 2012 | 08:01 PM
monster12valve's Avatar
I ordered the cts monitor.. Haven't received it yet. But I have the analog gauges in my cummins and wanted something different. I will post a review when I get it and mess with it
Old Jul 9, 2012 | 09:45 PM
Curry's Avatar
I got my insight right after I bought my truck about 3 months ago. Worked great then all of a sudden stopped working. Ive been back and forth with edge over what could cause the problem. On a good note Im one of the very very few people to have this problem. Its a great setup tho. Also running 4 pillar pod with EGT, Fuel pressure, Volt, and boost.
Old Jul 13, 2012 | 02:18 PM
g2shuck's Avatar
I got my insight CTS put in last night and it works and looks great in the truck. Now I just gotta get my two gauge pod with a pyro and fuel pressure gauge. Hell it works so good that now I know I need to have my oil cooler replaced .
darkstardevil26
Price Quote - Request A Price
Oct 6, 2015 07:57 PM
David4684
Aug 10, 2015 03:59 AM
97cummins
Aug 6, 2015 02:40 AM
Dr67
Apr 30, 2015 12:36 PM
Bowling_77
Feb 22, 2015 10:58 AM
