Rough Idle
Old Jun 19, 2012 | 07:00 PM
twditmore's Avatar
Default Rough Idle
I have a 90 7.3idi that I picked up in a trade and the truck runs rough at idle and today while driving seemed to be missing a little. Stoped at a red light and it seemed to rpm up and then died took several attemps to crank. The tank was down to 1/4 stoped to fill up and now it seems to run fine. One time prior to fueling today when taking off truck seemed to stall out like it needed more fuel. I am wondering if the fuel lifter is getting weak no visiable leaks.
Thanks for the help in advance.
Tim
Old Jun 21, 2012 | 05:12 AM
DieselCrawler's Avatar
nope. you said the magic number. 1/4 tank and it dies. you fuel pickup is broken off. very common.
rough at idle can be many things. IP, injectors, compression.
Old Jun 21, 2012 | 08:54 AM
twditmore's Avatar
Default fuel pickup question
I will just keep it above 1/4 tank till I either find or build a flat bed for this truck not going to pull old bed just to fix.
Now important question is this a item that can be purchased from parts store or is there another way to fix with out purchasing a new item.
Old Jun 21, 2012 | 06:09 PM
to repair the pickup tube, a new "showerhead" can be bought from ford still.
Old Jun 21, 2012 | 06:47 PM
twditmore's Avatar
Default Good
Good I got this truck on a deal the fellow was short some cash for hay and I took this in partial payment. I have a 91 F350 with 290,000 plus and still a good truck so I want to put this one back into good shape and install a flat bed and get a paint job old trucks motor is in good shape just hasnt been maintained like it should have been and now little things are taking there toll on it. I will be asking lost more questions as this project takes feet .
Thanks
Tim
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
