Small twins set up
Old Jun 19, 2012 | 05:38 PM
F-350a'cummin's Avatar
Default Small twins set up
was considering a small twin set up with a hx35 and a hx40.. not looking to hook to a sled or anything just want quick spooling and low EGTs.. plus it would cool to be able to say i got twins haha what do you guys think?
or maybe a HT3B with the HX35
Last edited by F-350a'cummin; Jun 19, 2012 at 05:39 PM. Reason: Automerged Doublepost
Old Jun 19, 2012 | 05:55 PM
RAW's Avatar
RAW
My HX35/S471 spooled up pretty quick. It's a little slower now with the HX35/40 and S471, and a 16cm exh housing on the HX35/40. The 16cm exh housing flows much better, with less back pressure, but is a little lazier.
Old Jun 19, 2012 | 06:17 PM
S471 works great with the HX35. Let me know if we can help.
Luke
Old Jun 20, 2012 | 08:12 AM
Luke
what kind of egts can iexpect with stock injectors and 80hp injectors with the s471
unless i can get the s471 for pretty cheap i can get the ht3b for a pretty cheap price
Old Jun 20, 2012 | 09:02 AM
RAW's Avatar
RAW
I had a hard time surpassing 1300* towing my trailer with a set of 65hp injectors, and a Smarty stacked with EJWA. Granted I didn't have either chip maxed out while towing, it was working hard. Unloaded, chips maxed out, foot to the floor, still hard to reach 1300*.
Old Jun 20, 2012 | 09:29 AM
i got a deal working right now on a hx40, i guesss im gonna run it as a single for a while, when i get injectors i think im gonna go with the 40 and a bht3b for twins. or would you not go that route?
Old Jun 20, 2012 | 09:35 AM
RAW's Avatar
RAW
40's are known for a weak shaft, and lazy. I would build a HX35/40 hybrid. You use the compressor wheel and housing from the HX40, and put it on the HX35 cartridge. Some machining is required.
Old Jun 20, 2012 | 09:37 AM
i was considering that, what all goes into building a hybrid?
Old Jun 20, 2012 | 09:38 AM
RAW's Avatar
RAW
Have a look at this, I did it not too long ago.
https://www.dieselbombers.com/5-9l-2...machining.html
Old Jun 20, 2012 | 10:09 AM
doesnt seem to bad at all
