Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Electrical Gremlins
Old Jun 19, 2012 | 09:49 AM
gordie 1000's Avatar
Default Electrical Gremlins
I'm having issues with the electrical system on my 05 lly,batteries go dead overnight. put new batteries in, same thing, today I put the charger on it and it keeps kicking my charger off, but I can hear some clicking in the fuse panel, I found it to be the breaker for PARK LP so I pulled the breaker and no more clicking and it is taking a charge WTF? I have had the truck for a few yearsand when I first got it, if I let it set for more than 2 wks it go dead. Sometimes when I turn it off the transmission indicator [prndl] and the battery light will stay on. Can anybody give me some kind of idea what I am dealing with. I also pulled these codes a few days ago, P0401,P0404,P0405,P0700,P1404,P1621,V0073,V0106,. thanks for any help.
Old Jun 21, 2012 | 03:47 PM
allen2289's Avatar
Sounds like you have something shorting out that is drawing your battery down get a diagram and trace it from the park lp breaker you pulled
Old Jun 28, 2012 | 09:41 PM
how about all those codes?
Old Jul 12, 2012 | 01:25 PM
somebody has to know what those codes are
Old Jul 13, 2012 | 12:22 AM
2004LB7's Avatar
P0401: EGR flow insufficient
P0404: EGR open position performance
P0405: EGR position sensor A circuit low voltage
P0700: TCM requested MIL illumination
P1404: EGR closed position performance
P1621: control module long term memory proformance
V0073: ?
V0106: ?
Old Jul 13, 2012 | 01:26 AM
2004LB7's Avatar
Park lamp and egr wiring
Attached Thumbnails Electrical Gremlins-egr-wiring-lly.jpg   Electrical Gremlins-exterior-wiring-2-lly.jpg   Electrical Gremlins-exterior-wiring-lly.jpg
Old Jul 17, 2012 | 09:29 PM
Thanks for the help I really appreciate it
Old Jul 23, 2012 | 11:58 AM
2500HeavyDuty's Avatar
you're going to have to do a parasitic drain test to find out what is killing your batteries over night.
Old Jul 24, 2012 | 07:31 AM
Well, you are not going to believe this but I got pissed off and grabed the wire harness and shook the crap out of it and have not had a problem since???????
Old Jul 24, 2012 | 10:24 AM
2004LB7's Avatar
i believe it. i also believe the issue will return if you didn't find the fault and fix it
culp7
14
Jul 20, 2015 10:13 PM
coryfast
Jul 6, 2015 06:02 AM
Squirt
Jun 19, 2015 12:40 PM
Hmcyl
Feb 1, 2015 04:18 PM
Polaris04
Dec 1, 2014 08:27 AM
