ICP related issue.
Old Jun 16, 2012 | 06:44 PM
svt28640's Avatar
Default ICP related issue.
My truck when you start it lopes an throttle pedal is unresponsive.. Unplug the icp its fine.. Replaced the icp sensor... twice... new hpop, lines, ipr, cps, fresh oil. Any ideas?
Old Jun 16, 2012 | 07:14 PM
CSIPSD's Avatar
It drives fine with the ICP unplugged?
Old Jun 16, 2012 | 07:36 PM
svt28640's Avatar
yes
Old Jun 16, 2012 | 09:27 PM
Fourwheelrevolver87's Avatar
I would check the engine wiring harness...sounds like an electrical issue to me. Check the icp and ipr well for any rubbed, melted or broken wires.
Is your truck chipped or have a programmer? Do you have acess to a scan tool?
Last edited by Fourwheelrevolver87; Jun 16, 2012 at 09:27 PM. Reason: Automerged Doublepost
Old Jun 17, 2012 | 02:41 AM
svt28640's Avatar
Shut Mouth
Yes its chipped ts 6 pos and it does it with chip out. An yes I have snap on scan tool
Old Jun 17, 2012 | 08:34 AM
On the datastream with the icp plugged in what is the icp psi reading? Unplugged icp should read about 700psi...
Old Jun 17, 2012 | 03:02 PM
svt28640's Avatar
It will not run plugged in
Old Jun 17, 2012 | 09:32 PM
It will not run at all plugged in? Did you check out all of the wiring?
Do you have a cel/ses? Any codes?
Last edited by Fourwheelrevolver87; Jun 17, 2012 at 09:32 PM. Reason: Automerged Doublepost
Old Jun 19, 2012 | 08:21 AM
svt28640's Avatar
Only has codes when icp is unplugged
Old Jun 25, 2012 | 12:39 PM
Did you figure anything out with your icp issue? Find any rubbed, broken or shorted wires?
