Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
POR15 opinions
Old Jun 16, 2012 | 03:56 PM
AdrianD's Avatar
Default POR15 opinions
I'm looking to clean-up some rust on the underside of my Jeep and I was looking at POR15 to treat it after wire wheeling the rust.
What's the general opinion on POR15 ? Good / Bad ?
Old Jun 18, 2012 | 09:28 PM
TheOtherNick's Avatar
Works great.
Old Jun 19, 2012 | 09:57 PM
bill-d-c's Avatar
I've used it on two trucks, one with slight surface rust, the other with major rust problems. Works very good, but is alot of work. You need to do all four steps to make it last.
1. Marine clean
2. Metal prep
3. Por-15
4. Top coat
All is obtained from your Por-15 dealer except the top coat. Some will tell you that the top coat is not necessary because the frame isn't subject to UV rays (Por-15 has no UV protection). But it will fade over time if you don't use a quality top coat. Took me about 16-20 hours on each frame (including running gear and suspension).
Bill
Old Aug 27, 2012 | 11:05 PM
yakdaddy42's Avatar
works great just dont get it on you or you will wear it for days
Jmrobinson
Sep 11, 2015 12:30 AM
wannadrag
May 25, 2015 03:07 PM
kobe123
Apr 30, 2015 12:00 AM
Krizacosta915
12
Apr 9, 2015 04:28 PM
bocho214
Jan 29, 2015 09:19 AM
