94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
At what point do I need to upgrade the head studs
Old Jun 13, 2012 | 11:23 AM
Psd97's Avatar
Default At what point do I need to upgrade the head studs
97 twin turbo, stage 2 injectors with propane and a php chip and 8 inch stacks is the plan. I have all the parts bought and are being assembled as we speak. But at what point should I start reinforcing the engine like head studs and girdles? Any other supporting mods suggested I'd be happy to hear.
Thanks
Old Jun 13, 2012 | 12:11 PM
joebob3093's Avatar
Moderator
girdle is not needed for till your maybe 600+? headstuds are a good idea is your around 40+ psi of boost
Old Jun 13, 2012 | 01:11 PM
CSIPSD's Avatar
Ditch the propane... Its great for cooking steak, bad for motors.
Whats your HP goal?
Old Jun 13, 2012 | 10:12 PM
Psd97's Avatar
My hp goal is loose as it has been throught the project. I've been wanting a big bad diesel since I was young when my grandfather brought home a f250. I just want as much as possible without breaking the bank more than I already have. I'll definitely look into new head studs. Arp? Or? Anything else I should check into to squeeze some more horses out of this truck? The reason why I decided on propane instead of nitrous is because I had a spare turbo around so I figure I could get some more boost and then push extra fuel too. A buddy of mine got a ton of power from his propane setup and has been using it for some time now with no problem.
Old Jun 14, 2012 | 09:29 AM
Mattman347's Avatar
Go with nitrous over propane, not everybody will have the same "luck". With stage 2's you won't need head studs, just a fuel system, HPOP, and a turbo upgrade would do good. The stage 2's are good for 400-450 RWHP.
Old Jul 16, 2012 | 11:33 AM
Cratos's Avatar
better stud it now if your using propain or nos!!.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
