Water in Diesel
Old Jun 12, 2012 | 04:58 PM
Simmering's Avatar
Default Water in Diesel
I have a 2004 F250 6.0 that I got about 3 months ago with about 140k miles on it. The water in fuel light came on recently after purchase and I drained the separator and changed the filters per the manual. The light came on again after about 2 days. I drained it again. The light came on again. I have now drained 3 times. The third time I let it drain for about 15 minutes. I have tried several bottles of stuff to remove water and/or clean the tank.
Am I supposed to let it drain until nothing more comes out? Am I supposed to reset the light somehow or is automatic? What should I try next?
Thanks. This is my first diesel truck.
Old Jun 13, 2012 | 01:52 PM
j johnson's Avatar
if u have water in the fuel..then u need to drop the tank clean and dry it..then get about 10 gals. of good clean diesel...blow out the fuel lines change fuel filter reprime the fuel system ..that should get u started in the right direction..hope this helps..
Old Jun 13, 2012 | 04:31 PM
Simmering's Avatar
I'm not sure what you mean about the 10 gals of good clean diesel. Am I supposed to blow that through the lines or put it in the tank? Is there somewhere I can find directions for blowing out the fuel lines? I'm pretty sure I could drop the tank and clean it out, but from there I'm a bit unclear about what you mean.
Old Jun 13, 2012 | 09:09 PM
j johnson's Avatar
put the clean diesel in the tank once uv put the tank back in...were u fuel lines connect to the fuel tank..use compressed air to blow the bad fuel out of the lines..then replace the bad fuel filter with new one...rebleed the system and u should be good to go..except if u damaged the injectors..thats another can of worms!!
Old Jun 13, 2012 | 11:06 PM
Ltk's Avatar
Ltk
my water in fuel light has been on since the day i bought the truck. never have had any problems. i believe all the steps mentioned above are a littleeee too extreme for this. ever think it could just be a bad WIF sensor?
Old Jun 13, 2012 | 11:16 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
water is very bad if you get a load of it in your tank. if your are not seeing it when you drain your filter drain you might have a bad sensor.
Old Jun 14, 2012 | 04:21 AM
Sarafin's Avatar
If it was just a bad sensor, then why would he be able to drain water out?
Old Jun 14, 2012 | 07:58 AM
diesel pap's Avatar
sorry i didnt see that. if you are draining water out you need to get rid of it. pulling the tank is a sure way to get it out.
Old Jun 14, 2012 | 09:49 AM
tiremann9669's Avatar
Drain it into a glass bottle so you can look at it and see if it's water or just fuel you're draining out, could be a bad sensor.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
RatsMC
May 4, 2015 05:25 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
