adjusted valves and engin still sounds chattery
Old Jun 11, 2012 | 12:18 AM
Bigred7.3's Avatar
Default adjusted valves and engin still sounds chattery
i adjusted the valve lash they wernt off too much all the intake valves were about 4 to 6 thousandth off and exhaust valves were all about 8 thousandth off but i set them back to spec anyways, but the engin still sounds chattery at idol. she dosent run bad or show any sign of loss of power or bad mpg but i compared her to my friends 0 6at idol and his dosent have ithe chatter that i hear on mine, anyone havr any ideas?
Old Jun 11, 2012 | 11:52 AM
steved's Avatar
Programmer/Chip?
Old Jun 11, 2012 | 02:59 PM
dmaxkiller's Avatar
small amount of injector rattle maybe?
Old Jun 11, 2012 | 05:12 PM
steved's Avatar
That's what I was wondering...if there is a programmer, that will typically cause it. Although worn injectors are noisey too...
Old Jun 11, 2012 | 05:32 PM
dmaxkiller's Avatar
mine will do it when i first start it in the morning and take off. goes away after a half sec.
Old Jun 12, 2012 | 01:46 PM
Bigred7.3's Avatar
nope no programer or chip engin is all stock. im also hearing a slight knocking noise wen i craw underneath, but the knock and chatter goes away wen im driving its only at idol
Old Jun 14, 2012 | 07:53 PM
Bigred7.3's Avatar
anyone?
Old Jun 14, 2012 | 09:27 PM
dmaxkiller's Avatar
sounds like injectors chatting
Old Jun 14, 2012 | 11:00 PM
cummin_un_glued's Avatar
FormerVendor
injectors or high rail pressure at idle....also you didnt say which transmission it is but if it is a stick then possibly a clutch/transmission noise?
Old Jun 19, 2012 | 07:47 PM
Bigred7.3's Avatar
its auto tranny,
injectors sounds like it, the truck does have 186,000 miles
