Charging issues
Old Jun 9, 2012 | 12:32 PM
MrPontiacRacer's Avatar
Default Charging issues
Hello,I have a 94 suburban 6.5td the problem I am having is that when you turn on both blower motors,head lights,radio volt meter goes in to the red say 9-10 volts turn it all off goes back to 14 volts,but if you check voltage at alt and batteries with the blower motors on head lights radio on it is 14 volts when gauge is reading 9-10 volts I have cleaned and check all grounds the batteries have load tested good and alt has tested it is good.I have checked voltage at fuse pantle it is reading whatever the gauge reads thanks for the help
Old Jun 9, 2012 | 11:18 PM
Jeff Bennett's Avatar
So are you running your batteries dead? Not sure what the issue is....
Old Jun 9, 2012 | 11:39 PM
No the battries are not going dead, but having low voltage to fuse box gauges jumping around and radio cutting off
Old Jun 10, 2012 | 11:10 AM
ebarresi5894's Avatar
how is the cable that connects both batteries?
what are you getting when the truck is running high rpms? should be 14.6
my truck used to do the same thing, i ran anouther power cable from battery to battery.
turned out to be fine.
the gauges in these things arent the best in the world either
Last edited by ebarresi5894; Jun 10, 2012 at 11:10 AM. Reason: Automerged Doublepost
Old Jun 10, 2012 | 11:00 PM
At high rpm it stays 9-10 volts untill you turn everything off,Ill try the battery cable,where is the main power feed to fues pantle at
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
Apr 11, 2015 02:47 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
