6.9 p1689
Old Jun 5, 2012 | 04:31 PM
joeycad1's Avatar
Default 6.9 p1689
Have 2000 6.9 with about 200k. started little slow a couple times then quot starting. P1689 and P1689pd . diesel Supply not running,but wifll if i wire it straight to battery . Has power at pigtails plug tithe pump until I plug it in. Actron cp9125 scanner. Any ideas???
DiesEl supply pump will not run plugged in
There is power at the pigtails until i plug the pump to it and the wire loses power
5.9 Cummins
Old Jun 8, 2012 | 02:33 PM
dmaxjenn's Avatar
IT'S A GIRL!
P1689 - No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
check your fuel pump relay by replacing it with a new one....
Blanton
Apr 15, 2015 06:29 PM
greasesheik
Apr 9, 2015 09:33 PM
tumble72
8
Nov 27, 2014 10:31 PM
tumble72
Nov 10, 2014 08:41 PM
greasesheik
Oct 28, 2014 08:05 PM
