have a code. assistance please.
Old Jun 2, 2012 | 08:00 PM
1st Diesel's Avatar
Default have a code. assistance please.
P2285 just came up. How hard is it to change the icp on a 2003 6.0 since its on the back of the motor. Easier to go from the top or underneath?
Old Jun 2, 2012 | 09:01 PM
RanchhandTCR's Avatar
you can get it from the top, its some what a pain but it can be done..
Old Jun 3, 2012 | 02:29 PM
1st Diesel's Avatar
Do u have to take the Turbo out?
when the icp goes bad is that what also causes a small oil drip out of the back of the motor just above the bell housing??
Old Jun 4, 2012 | 07:40 AM
Lilpooh's Avatar
You don't have to take the turbo out. You can either unbolt the Degas bottle an pull to the side, then remove the FICM to get to the ICP. Or if your arms are skinny and long enough, you can reach it from under the truck by reaching up and feeling your way to remove it.
Not much room back there to swing a wrench/socket, I use a 1 1/16" open end wrench, cut down to 4.5" long.
Yes, a failed ICP can cause oil leaking, make sure you get the replacement wire harness and plug.
Old Jun 4, 2012 | 09:46 AM
Mdub707's Avatar
Quite common on the early ones. Replace the ICP sensor and the pig tail going to it. The oil leak is what causes it to go bad typically. The oil corrodes the wiring. This is why the ICP sensor was moved to the passenger side valve cover in later years.
Old Jun 6, 2012 | 11:13 PM
1st Diesel's Avatar
thank ya'll for the help. not looking forward to doing this. figured i'm gonna hopefully get it done this weekend. ordering a 5" straight piped exhaust with a 4" downpipe and 6" tip that I would like to put on at the same time as the icp to get it all done at once. Then clearance lights. .
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
robbyS
Apr 16, 2015 02:22 PM
UC Kid
Nov 7, 2014 10:56 PM
