Power Steering Problem-Gearbox?
Old May 30, 2012 | 06:06 AM
mohrt's Avatar
Default Power Steering Problem-Gearbox?
Hello everyone. I am having problems with my power steering on my 2001 F250 4x4. On a couple occasions, it is like the power steering quits. The wheel is hard to turn. On a couple occasions, usually about the same time, when taking off from a stop sign or backing out of a parking space, it has popped a few times when I turned. I have siphoned out the fluid and put in new and it did it again.
Does this sound like the PS box is bad? It doesn't appear to be one direction only when the power goes out. I have checked the linkage and everything appears fine. I bought the truck new and occasionally felt a slight grind or small rough spot in the steering since it was pretty new, but it never really amounted to anything and was very rare. I am thinking that was the start of this problem. Please help diagnose.
Also, I put in regular power steering fluid. That is what it takes, right?
Thanks! matt
Old May 30, 2012 | 11:48 AM
BucktownPSD's Avatar
Not power steering fluid . ATF. I'm having issues with mine too I think. It takes two hands to turn my wheels when I'm sitting still, no brakes. It's impossible to turn with the brakes applied. I've also noticed my brakes don't seem to have as much power.
Old May 30, 2012 | 05:01 PM
TheRobenator's Avatar
Tried just throwing a new PS pump on there?
Old May 30, 2012 | 06:01 PM
mohrt's Avatar
Not yet. I am taking it to a shop tonight. He was thinking with the popping, maybe it is the u joints on the front. I don't think that would explain the loss of power steering though. Seems to me it is the pump, gearbox, or both. I did learn today ATF instead of PS fluid. I only have a half of quart in maybe before I learned how to flush it. I will need to flush it now for sure. I will wait until I see if the gearbox is bad.
Old May 30, 2012 | 06:12 PM
CSIPSD's Avatar
PS fluid is fine. Ford says ATF, but both work.
Old May 31, 2012 | 04:40 PM
mohrt's Avatar
Good to know. Thanks! At least the little I have in there won't cause any damage while I drive it in to town.
Looks like it is the driver side u joint in the front axle. Wasn't a power steering system problem after all. It will set me back about $400.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
