1996 ebp
Old May 27, 2012 | 06:19 PM
dlp's Avatar
dlp
Default 1996 ebp
On the front passenger side of the engine, there is a tube that comes off the exhaust manifold & goes uo to the exhaust gas back pressure regulator. The tube on mine is broken, can it be plugged off? Thanks!
Old May 27, 2012 | 06:26 PM
twinboys's Avatar
I think what you are talking about is the tube that goes to the ebp SENSOR.
I'm not sure what disabling it will do. I would replace the tube.
Maybe you could block it off so the exhaust doesn't leak and unplug the sensor until you can replace it.
Old May 28, 2012 | 06:51 PM
Fuelfool's Avatar
replace the tupe, if you unplug it on that end it will cause a falt code, but in the future if you decide to eliminate the system on the turbo you can unhook things on that end with no codes...
Old May 28, 2012 | 09:24 PM
twinboys's Avatar
Of course it is going to set a fault code, that is why i said
Without it plugged in, it should run better on a default value.
UNTIL YOU CAN PEPLACE IT.
Old May 29, 2012 | 09:19 PM
Fuelfool's Avatar
Twin, I was not trying to corect you, I was just adding that in the future if he decided to remove his ebp system he could unplug the solenoid under the turbo without any fault codes.
Old May 31, 2012 | 11:31 AM
docweld's Avatar
is it better to remove it or fix it? I have a 2000 7.3 and removed the ebp SENSOR and found it blocked. I do not have any codes. Would the truck run better with it fixed or with out it? I would like some info before I clean it, thanks!!
Old May 31, 2012 | 12:31 PM
twinboys's Avatar
fix it.
Old May 31, 2012 | 03:19 PM
docweld's Avatar
can't get any more to the point then that, thanks!
chaoticape
Apr 12, 2015 05:45 AM
Derag2
Apr 2, 2015 07:57 PM
rajdiesel
Mar 14, 2015 07:11 AM
Fishy816
Jan 11, 2015 08:31 AM
UniqueCopy
Dec 14, 2014 11:37 AM
