T/C lock up switch help
Old May 25, 2012 | 09:58 AM
SRTcummins's Avatar
Default T/C lock up switch help
I have a 99 cummins and the ecm behind the air box has 3 plugs the 2 end ones are black and middle one is white. Which one do i use? and if i use a resistor do i need to do the trans relay jump in the fuse center.
Thank you!
-nick
Old May 25, 2012 | 10:02 AM
RAW's Avatar
RAW
Hopefully these helps:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
https://www.dieselbombers.com/5-9l-1...ic-repost.html
Old May 26, 2012 | 11:01 PM
Russ Roth's Avatar
I use a 33 ohm #271-1104 Radio Shack resistor and leave the relay in. Mine has been like that about 5 years and has worked fine.
cumminspwr11
12
Oct 17, 2021 03:50 AM
cumminsp12v
24
Apr 20, 2015 12:05 AM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
IslanderXJ
Dec 17, 2014 04:14 PM
