Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
Excursion 12v 47rh swap
Old May 24, 2012 | 09:07 AM
tommyfulano's Avatar
Default Excursion 12v 47rh swap
Hi guys this is my first post I have been reading this forum for some time now. Im getting some money to start my project and i have some questions and I know that there other posts around that talk about excursions swaps but none talk about a12v with a 47rh. Without that said.
What kind of trans mount adaptation I have to do with a 47rh?
What would better to get a v10 or 7.3L diesel excursion?
Its going to be 4x4. Do I have to switch the input on the t case?
If I get the 7.3L would I be able to use intercooler and trans cooler?
With a 12v what kind of electronics im looking to make the ford dash work?
Thanks for all your help all your comments would be really appreciated
Sent from my DROID BIONIC
Old May 31, 2012 | 10:38 PM
joshbaker's Avatar
Im pretty sure the 47rh will bolt right up to the 12v. I dont know bout the rest.
Old Jun 13, 2012 | 07:43 PM
empty wallet's Avatar
47rh was the 12 valves tranny in 94-95 so that bolts right up. what t-case are you using? You should be able to use intercooler, what size are the inlet/outlets on the ford ic? And tranny cooler may work too with modifications or custom lines + fittings
Old Jun 23, 2012 | 02:16 PM
Sorry haven't got there yet im collecting info to know the details
Old Jun 27, 2012 | 01:43 PM
photomonkey's Avatar
Interested in the results here...
Have you budgeted the project yet? I'd LOVE to do this. I like the build quality and body styles available from Ford but don't like the powerplants.
Old Jul 7, 2012 | 10:39 PM
hi guys im back finally got my truck yes a truck i know i started this as an ex in mind but i found this 01 f250 7.3 diesel 4x4 in better conditions and cheaper.
with that said my next question for all u 12v racing experts im trying to build my motor from my 94 2500 donor truck which has 220k miles the motor is in really good contions i got the truck from my buddys dad that he had it since 60k miles.
I want to buy a good rebuild kit and some nice pistons and get like a 4k gsk with the hd valve springs and a lift pump also some injectors and a 66mm turbo.
my goal is to be aroud 500-600 HP i would be super happy
Also behind that im planing on building the 47RH with a full rebuild kit from suncoast and a billet triple clutch tc.
Also where should i buy my conversion parts since im not using ford trans i only want like the ac hoses and motor mounts and the np273 input tach kit alternator etc..
With that said i would like some input and opinions and all of them would be gratefully appreciated.
this is the rebuild kit i found
http://www.puredieselpower.com/catal...t-p-28791.html
Old Jul 8, 2012 | 12:32 PM
Mdub707's Avatar
Destroked - THE Cummins Conversion Company : Home Page
Jonrarick
Oct 25, 2016 01:32 PM
savage-rider
Diesel Engine Conversions
Sep 26, 2015 12:43 PM
otpracer
Sep 18, 2015 02:31 PM
Murdock
Apr 12, 2015 06:16 PM
Ryans71
Dec 24, 2014 08:47 AM
