rough starting 03 duramax
Old May 21, 2012 | 08:07 PM
NeedinMoPWR's Avatar
Default rough starting 03 duramax
runs fine after its been started. Has a new set of glowplugs in it and the starter isn't giving out. it takes a good 5-10 seconds of key turning to get her finally started...any ideas?
Old May 23, 2012 | 07:10 PM
MRaynor's Avatar
Have you tried replacing the fuel filter? If you have, check all your fuel lines to make sure it's not sucking a little bit of air somewhere.
Old May 24, 2012 | 12:25 AM
2004LB7's Avatar
sound like a leak on the suction side of the fuel lines.
try priming it till hard first and see if it starts quicker
if yes, check around the filter/housing. check the bleeder screw (common fault), cracked or damaged water-in-fuel sensor or even the housing.
also make sure none of the rubber hoses are cracked, etc. you can also replace the short hose on the output of the filter with a clear one to see if any air bubbles in the fuel.
Old May 24, 2012 | 03:11 PM
thanks guys
bdbfam
Aug 31, 2015 09:06 PM
jt19
Aug 20, 2015 12:18 AM
hurriedcoyte
Jun 19, 2015 06:26 AM
Snoobly
Dec 11, 2014 11:59 AM
duramaxtuner
Dec 10, 2014 01:24 PM
