Bad mileage at cruising speeds
Old May 20, 2012 | 08:08 PM
fordornothing's Avatar
Default Bad mileage at cruising speeds
I did a quick check on other threads with no luck. Here's the deal, I drive interstae alot. At cruising speeds (75- 80 MPH) I'm lucky to get 12 mpg. I realize I'm not going to get 20 in a 8K pickup but it just seems low to me. The mods are in my sig. It doesn't make a difference on what setting I have the chip on either. Let me know what you guys think.
Old May 20, 2012 | 09:30 PM
cpalmer's Avatar
That's what I get too at that speed. Slow down to 65 and I'll get about 16 mpg.
Old May 20, 2012 | 09:43 PM
gijohn45's Avatar
I have a 01 with the auto and mine gets a bout 17 mpg at 65-70 but once I go above that I start dropping quick... at 80 mph I'm getting 14 mpg
Old May 21, 2012 | 07:26 PM
I think is what I'll do, is from Hays to Burlington I'll run at 70 mph, then Burlington to Denver I'll run at 75 ish and see what kind of difference that makes.
Old May 21, 2012 | 08:30 PM
riddick01's Avatar
like everyone saying there is a HUGE drop once ur over 65 or 70. if for some reason it doesnt change you might check your fuel filter (i gained 1-1.5mpg when i bought my truck by changing it bc the previous owner never did)
Old May 22, 2012 | 04:19 PM
95powersmoker's Avatar
65 is where I get my best mileage... 70+ and it starts dropping hard... Slow er down or continue cruising at those speeds and deal with the mileage...
Old May 22, 2012 | 04:39 PM
gijohn45's Avatar
I was once told that the sweet spot for the 7.3 is between 1750 and 1900 RPM if you keep the truck in that zone your going to get your best mileage... I have found this to be true with my truck...
Old May 22, 2012 | 04:45 PM
1900 RPM would be about 60 on mine. The fuel filter is fine, I checked it about a week ago. Now I'm not sure if this has anything to do with it but according to the gauge, when the water temp is in the normal, the engine still sounds cold. Similar to a OBS when it's cold. Any ideas on this?
Old May 22, 2012 | 05:11 PM
RanchhandTCR's Avatar
EVen if the Speed Limit is 75 to 80 Ill drive 65 to save fuel...
Old May 22, 2012 | 05:58 PM
Well I might have to try that, I guess I'm not in to much of hurry to get places.
