What are the dangers of replacing my dead turbo.
Old May 18, 2012 | 11:53 PM
HeavyMetalDiesel's Avatar
Default What are the dangers of replacing my dead turbo.
A few months back i bought my neighbors 1993 6.5L Turbo diesel 2500. Well the turbo works as well as a screen door on a submarine, i mean not a peep. Now, i have the money to get a new one, its in the works and such. Having lived beside this truck for the last 15 years or so, i cant ever remember hearing the turbo spool up, and ive been around it quite a bit over the years. Now my question is, having had the turbo inoperative for possibly years, could there be any issues with simply putting a new one in and firing it up. Intake is perfectly clean, it runs like a champ, always starts up right away, grey smoke on startup.
-Shaggy
Old May 19, 2012 | 02:12 AM
cviola2005's Avatar
how well could a turbo motor run with an inoperative turbo? i would think it would restrict airflow, but im a noob on turbos...
Old May 19, 2012 | 11:11 AM
ebarresi5894's Avatar
nope there should no problem, my truck had a bad vaccum pump for like a year. put a new wastegate on it it ran like a pro. however, if your doing a TM i would suggest a boost gauge and get a pyro gauge as well.
Old May 19, 2012 | 02:33 PM
Eddiebuntain's Avatar
How do you know the turbo isn't working? Is the shaft seized or broken, or does it smoke a lot? I'm not familiar with these trucks, but factory set-ups are generally designed to be as quiet as economicly possible to avoid NVH complaints from consumers. You're probably right that it's not working, I just would hate to see you spend a bunch of money to replace the turbo and have the truck continue to behave as it already is. And x2 on the boost and pyro gauges.
Old May 19, 2012 | 06:09 PM
Red_Rattler's Avatar
High Tech Redneck
6.5's make about 8lbs of boost and you will not hear them over that clatter of that motor.
Old May 20, 2012 | 12:13 AM
Trust me the turbo is not spinning at all, the engine is also pushing 405,000km.
Old May 20, 2012 | 07:40 AM
High Tech Redneck
It will work just fine. No worries
Old May 20, 2012 | 10:25 AM
With that many kilometers, it may have other issues not related to the turbo, though. Just be prepared
Old May 20, 2012 | 05:34 PM
I have 5 in stacks with a TM and I can only hear mine under 1800rpm
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
