86 f250 6.9 fss replacement procedure
Old May 15, 2012 | 07:23 PM
rapidroy5858's Avatar
Default 86 f250 6.9 fss replacement procedure
Thinking i need to replace the fss on my 6.9 that is if the ip checks ok, can anyone provide info on this?
Old May 15, 2012 | 07:59 PM
DieselCrawler's Avatar
have a good shop do it. if anything is out of adjustment when reinstalling it, the pump could go to WOT and cause a run away. it is located inside the pump.
Old May 15, 2012 | 10:39 PM
4x4manonbroke's Avatar
That woould not be a good deal.....LOL... had a detroit do that.... had to cut fule line..... almost destroyed it... had to re-pulkl motor and re-due the mains and rod bearings.....OOPS !!!!!!!!
Old May 16, 2012 | 05:06 AM
also i am curious where you got a new FSS from?
Old May 16, 2012 | 11:12 AM
Stanadyne makes one, there is a link posted in here somewhere for it, 98.00 bucks
If anyone has the procedure for replacing the fss switch i would like to read through it, also any info on troubleshooting the ip would be very helpfull is there is way to determine whether or not the ip has failed?
Thanks
Last edited by rapidroy5858; May 16, 2012 at 11:12 AM. Reason: Automerged Doublepost
Old May 16, 2012 | 04:56 PM
you never really said what your issue is. what is happening? also fill out your signature so we know what the hell we are working on.
Old May 17, 2012 | 08:20 PM
!986 f250 6.9
Has excellent fuel pressure to the ip,
cranks fast new batteries
no fuel past ip to injectors
Has 12 volts at fss , no click at fss when 12volts applied to solenoid...n
no click means no fuel to injectoors
all I want is the procedure to replace the fss would like to read through whats involved to decide if I can do it or I should send it out
Old May 17, 2012 | 09:25 PM
call a pump shop. that is not a standard job that anyone will have info on how to do. also just curoius, which post are you giving 12+ to?
Old May 18, 2012 | 08:00 PM
I have found some info on changing the fss sounds pretty simple and straight forward just need to take care to get gov arm in proper position when reassembling.
I am applying 12 volts to the top electrical spade on thee ip there are 2 one on front towards fan thats the fss the other is the cold timing advance
Old May 19, 2012 | 07:46 AM
okm, just making sure you was on the correct terminal.
greasesheik
Apr 9, 2015 09:33 PM
greasesheik
Nov 20, 2014 12:01 AM
