Need help with new clutch and trans questions
Old May 13, 2012 | 09:41 PM
TylerJack's Avatar
Default Need help with new clutch and trans questions
Hi guys I have a question about clutchs and the NV5600 trans on a 2001 dodge.
I need a new clutch but money is tight right now, so for that reason I was considering the Valairs. My old clutch was Hasley street puller dual disk. I have a slightly larger turbo and injectors and no other mods. I tow very very little, but use my truck to go up and dirt and mountain trails to my hunting grounds. So out of this:
1. Valair clutchs I read mixed reviews what to you think?
1a. Can I use the old fly wheel if its surfacealbe?
2. What kind of clutch should I get for good street manners?
3. I think my old clutch was dragging, how do you adjust the cluch on the dodge?
4. The input shaft on my nv5600 has a bit of end play (up/down, left/right) is that normal? Considering the end isn't supported by the polit bearing.
Tyler
Old May 14, 2012 | 06:40 AM
welderboy250's Avatar
Play in the shaft is bad. That means there is no preload in the trans bearings which will cause them to pit. The clutch, I don't think u can use Ur daul disk flywheel for any single disc. Not sure about using it with a different dul disk. I'd say vlair is as good as any other aftermarket clutch.
Is your old clutch slipping? U mentioned a dragging, do u mean its hard to get in gear if Ur sitting still with the engine running? If that is the case u may not need a clutch, but rather some attention to the hydraulics (master and slave cyl).
I may be interested in giving u a few bucks for Ur old clutch. Where r u located?
Last edited by welderboy250; May 14, 2012 at 06:40 AM. Reason: Automerged Doublepost
Old May 15, 2012 | 08:51 PM
Boondockers's Avatar
I've got an old clutch out of my 98.5 24v it has the 5 speed It was not slipping when I replaced it with a valair . I have clutch pressure plate and fly wheel but don't think it is the same in the 6 speed tranny.
Old May 16, 2012 | 07:03 PM
Valair1's Avatar
FormerVendor
it is normal for some left to right up and down on the input shaft, just no in and out and it should spin smoothly.
Old May 22, 2012 | 08:02 AM
Fire Power's Avatar
If you want it to last that is not good!!!!!
Posted from my ifail when I should be working
Old May 22, 2012 | 12:12 PM
scottmorgan's Avatar
i bought the valair clutch and i love it i had a stock clutch befor and could not belive how much power i lost through the stock one. i have mine for a year now and it is great i got the kevlar and ceramic clutch... i wish i would have saved the money and got the ceramic to ceramic that was higher torqe and hp.... the kevlar and ceramic dont slip like the stock clutch it will shake the truck a little on tack offs but it aint that bad unless you are at a coplete stop with no trailer if you have a little wieght on your truck though it takes off smoth as combee it just grabs and goes if you want though!!
ctd04x4
Sep 11, 2015 03:50 AM
kryz9903
Jul 2, 2015 06:14 AM
lkfldredneck
Jun 25, 2015 04:51 PM
CrazyLoon
Apr 3, 2015 02:43 PM
South Texas Goat
Dec 30, 2014 11:44 AM
