TS Performance 6 position Chip
I ordered this for my 97 Stroker, will be in today so I will be installing it this afternoon. Any advice from those who have already done this install?
Sent from my DROID X2 using Tapatalk 2
Super easy...
http://www.totaldieselperformance.co...stall94-97.pdf
just make sure you get the silicone off but don't try to kill the contacts... I use my fingernail first to get the silicone off, then once I think it's all gone, give it a few scrubs with the scotchbrite... Too much cleaning is worse than not enough because it's a difficult process to go back on...
Also, leave your keys in your pocket and disconnect the batteries...
Thanks, I have the box out now and cleaned the terminals. The directions on their website were wrong so I did more work than was necessary to remove the box. The directions you sent were dead on, but I was done removing it by the time I checked for a response. Oh well.
YAY!
Chip installed, truck reassembled, everything works on all 6 settings, will be taking the truck out for a test drive shortly. Will report on my MPG increase after I get back from Texas in a week; leaving tomorrow for Texas and taking the truck.
YAY!
I have been considering getting one of these chips, but was told not to put the TS chip in unless I put an inner-cooler on my engine first. Also, can this be used on a stock 7.3 with a 3" downpipe, or do I need to add the inner-cooler?
It can definitely be used without adding an intercooler...
