installing injectors 1990
Old May 1, 2012 | 06:03 PM
codycatract's Avatar
Default installing injectors 1990
1 of 2
i have a 1990 cummins im putting im my f350 i have seen videos how to pull injectors im cerious how to put them back in? just tap them in with a socket over them?
2 of 2
i am swapping a nv4500 in it as well, if i get clutch pedal bracket from a 5 speed ford will it just bolt up under there ? or do i have to drill holes for bolts and the slave?
Old May 7, 2012 | 08:21 PM
somebody has to done this before
Old May 7, 2012 | 08:42 PM
peak-j's Avatar
The injectors should only go back in one way, just make sure the body and the hole is cleaned up good. Wouldnt hurt to put a little bit of antiseize on the body also. Just dont put any lower than the copper washer. As far as the pedal assembly goes, find one out of the same year of truck or whatever years were the same and use it. You will just have to look and see if the holes are already there in your truck, if not, make holes!!
Sent from my Motorola Electrify using Tapatalk 2
No3l
Jul 16, 2015 10:52 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
